Street Racing & Kill Stories Basic Technical Questions & Advice
Mustang vs Camaro
Old 12-16-2016, 02:57 AM
  #181
Deeohgie69's Avatar
Originally Posted by Prototype007
Wow guys look! It's a list full of sub 500 whp cars that uses high stall converters, but don't run 2.73 gears.
https://ls1tech.com/forums/drag-raci...1-74-bump.html
All those silly boys should know they'd be faster if they ditched those steep gears and got them some good ole gas saver gears!
More tears from Deeohgie and Jake in 3, 2, 1, go!
Dude, you are seriously a bleeding vagina. You seem to be the one making tears, not me. I'm sorry that you cannot let it go and you have to try and post nonsense that doesn't prove anything. I gave you the info, I said you are free to call yank, and I told you to use the search feature to find others that haven't gotten much if any gains from the gear change on a higher stalled car.
Geez, get over it already. You're worse than high school kids arguing about who can drink more beer. I don't care what you post, you see it your way and that's fine. I'm happy with my car, I'll stick to what I do and you stick to you. I'm good with how my car runs. It's faster than 13's, slower than 8's and somewhere between 600-850rwhp. You seem to be hung up on me since you keep coming at me, so if there's anything you'd like to know, I will tell you man, just ask.
Old 12-16-2016, 04:32 AM
  #182
RedFuryZ28's Avatar
Originally Posted by JC316
It went 11.9@114 into a 35mph headwind with no changes. After he changed the tune, that is when he did the 11.87@117. Without a headwind, he would have been running in the 11.5@119 range, which puts you in as a 12 second catfish.
As for me, I don't need footage of my turd, I'm not the one talking **** about the potential to run 10's, while getting my *** kicked by a 13 second 2V and an 11 second IROC.
You have no clue lol. You didnt even know thatva stall works past 1st gear. So you think that .5 drop on your sixty foot won't net you a full second in the 1/4? His car is capable of 10s under normal circumstances. That puts me around 11.3. You probably don't even have anything worthy of racing.
Old 12-16-2016, 05:51 AM
  #183
corysmach1's Avatar
13.30*. Fixed it for ya mang.
Old 12-16-2016, 06:30 AM
  #184
408-99-f's Avatar
Originally Posted by ZNix
You will go faster with better gears. The less gear your motor has to pull, the faster it will be. It don't matter if your motor stays directly on peak power with a stall. It will have the mechanical advantage with better gears to get the car accelerating faster.
If you go higher gear and smaller tire, figure it out to be the same final gear ratio(to a extent) you should be faster than where you started through frictional loss, gear weight, rotating mass. Just wanted to put that out in the mix too.
Old 12-16-2016, 06:43 AM
  #185
sw07gt's Avatar
If you weren't scared of the track you could actually find out how close to an 11.3 you are.
Old 12-16-2016, 06:49 AM
  #186
7 Second Club
islander033's Avatar
13.3 is pretty close.
Old 12-16-2016, 07:19 AM
  #187
Prototype007's Avatar
A good point, but there's the one problem everyone encounters when trying to do so. The smaller/shorter a tire you use in order to try to gain back on gearing ratio, the less traction you have to work with due to a smaller footprint of the tire itself.
Then of course you don't have as much of a selection in exact tire heights to help achieve the overall ratio you may need to make optimal use of your rpm range and achieve your target mph.
As far as gear weight, when you start changing gears you'll be adding/subtracting overall material from the pinion gear in one direction and the ring gear in another direction.
Old 12-16-2016, 12:52 PM
  #188
JC316's Avatar
Is that seriously all you have to say to me? A months old thread about a stall? Weaksauce from the king of the one liners, I expect better entertainment out of you.
You really think Cwarta could cut a 1.6 sixty foot on the street? Cause I don't. I'm not even sure he could cut a 2.1 60, which means you're even slower.
Old 12-16-2016, 01:13 PM
  #189
Nick.H's Avatar
I'll give Jake $50 if he goes to the track and runs better than 11.8
Old 12-16-2016, 01:22 PM
  #190
RedFuryZ28's Avatar
You proved your ignorance to everyone with that stall bullshit. And now you're butthurt.
You think Cwarta COULDN'T cut a 1.6x sixty foot at the TRACK? Cause I certainly do. It doesn't matter what sixty someone cuts on the street, because it will never be timed, you stupid jackass.
Old 12-16-2016, 01:25 PM
  #191
RedFuryZ28's Avatar
How many times do I have to say that I don't give a **** about track times? It's always some other dumbass who brings track times into arguments about STREET racing. I wonder when people will realize how retarded that is.
Old 12-16-2016, 01:39 PM
  #192
Nick.H's Avatar
you think your car is faster than it is. That's why. I know you "don't care" (scared of) the timer, hence why I offered money. If you run 11.3 like you said your car is good for then I'll give you $100
Old 12-16-2016, 01:41 PM
  #193
Nick.H's Avatar
I wonder what kind of excuses you would have after a solid 12.1 pass. You'd probably still talk about how you could beat guys in here that are gapping you
  #194
7 Second Club
Jake always getting offered cash to floor his car. Says a lot about his character. lol
Old 12-16-2016, 01:42 PM
  #195
Nick.H's Avatar
I'm just that certain
Old 12-16-2016, 01:44 PM
  #196
JC316's Avatar
He ran 11.8 @ 117 into a 40 mph head wind and a 2.1 sixty foot because of oil all over the track. His car is capable of high 10s in normal conditions.
Oh the irony.
Old 12-16-2016, 01:47 PM
  #197
RedFuryZ28's Avatar
You don't have a clue about anything. Your 82 mph cammed ls1 proved that.
Old 12-16-2016, 01:49 PM
  #198
RedFuryZ28's Avatar
Oh the irony.
How is me talking about track times after someone else brought them up, considered irony? Tard
Old 12-16-2016, 02:06 PM
  #199
JC316's Avatar
Do you really want me to go back and quote all of your bullshit about beating 11 second cars? Like a truck that ran 11.6@118. Thats called bringing up track times. Talking about a car that COULD run 10's is bringing up track times.
If we want to stick to your formula, you lost a street race to a 2V mustang. Or the fact that we have a handful of street racing videos that show you getting your *** kicked. That should say it all.
Old 12-16-2016, 02:09 PM
  #200
RedFuryZ28's Avatar
Yes I've beaten a few 11 second cars quite easily. What have you beaten, besides your meat every weekend night? Where are your racing vids? And show me where I brought up track times first? I'll be waiting, simple jack.
Quick Reply: Mustang vs Camaro
