Bone stock 2002 Z28 vs Bolt on 5.br0
#101
Sincerely,
SRK
Or at least that's the general meaning that I've concluded.
#103
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
Just have to get used to the jargon...I guess
#104
I had a 2002 Firehawk Trans Am with the 345HP package on it. Even if all the LS1's did or do make 350HP, the stock Coyote in 2016 makes 435HP. That's still a substantial difference. Yes, I'm surprised that a 200lbs. weight increase would be enough to offset the power gap. Aerodynamically, the Mustang is much worse off than the Camaro, but I didn't think this would be enough to close the gap either.
Don’t get me wrong I would fully expect the 5.0 to win, it’s just not a blow out.
#106
There is no doubt there is a power disadvantage, I just know that even in stock form at 324rwhp I wasn’t anywhere close to 100 hp down from a 5.0 😉 if not mistaken it’s about 50-60hp and the weight difference levels things off slightly with the 5.0 still having a good advantage unless something else comes into play (heavier driver, heavier car, extra passenger, etc)
#107
I'm not sure people are getting the math here. Everyone keeps saying things like it's a 50-60HP difference etc. The 2015+ Mustang GT 5.0L is rated at 435HP vs. 345HP MAX for the LS1 F-body cars. The difference is 90HP. Even if you want to say that all LS1's are 350HP, that's still an 85HP difference. I know that's not to the rear wheels but I don't see any reason why the Mustang would lose more power than the F-body to the rear wheels.
#109
ahh Well that explains your confusion... once again I made 324rwhp... at 15% DTL that would be 380HP, 350HP max and I would only be putting down around 295rwhp. The 5.0 at 435 would be seeing about 370rwhp with the same rough calculation (though I understand stock 5.0 dyno numbers to be all over the place so they make well over 470 if you believe the stock ones that put down near 400rwhp.
#110
Neither of my cars are stock or I'd consider doing it. My 2016 Mustang GT 5.0L is close to stock though. I've done a few small things but the only thing that affects the dyno numbers is the exahust, which wouldn't have a huge impact on it. My Camaro SS is another matter. Besides not having been tuned, and the engine being in the wrong body, it's got 5.3L truck heads and a cam. I haven't a damn clue what was done to them before I got it.
#115
I would not even trust the manufactures advertised Hp since these are manipulated to sell more cars. To be honest, maybe we should not even be concerned with engine horsepower numbers. It is really about what you can put down to the tire anyway.
#116
Agree with Mach, I made 324rwhp/341rwtrq... regardless of the crank number.
#118
Agreed. That 15% is being generous. I think that may be more around 10 to 12% if that. Really no way to know though without comparing the dyno numbers from the engine alone vs the numbers from a chassis dyno.
I ran across this. Looks like in 1:1 gear the loss is only 1-2%.
However, when dyno testing in the direct drive (1:1) gear, power is delivered directly through the mainshaft of the transmission, so the only loss sources are windage, friction and drag, resulting in total at-the-wheel losses as low as 1.5 to 2 percent, according to the published data.
#119
It trapped 108.58 stock at 3440lbs... with me it was just shy of 3600lbs. You can crunch the numbers if you would like, if sub 10% was an accurate number then all 5.0 manual mustangs would put down 400rwhp... which also doesn’t add up.
I think alot of them dyno in 4th gear is why they are all over.
