Tune, cold air, & drag pack 6th gen vs full bolt on 16' 5.0
#42
Fastest one I've seen is 11.5@119. But he was full weight and using pump E85. 2400 DA that day. I went 11.2@121 with my old stock manifold that day
If they opened the track up for us in the winter. He pulled 500 lbs out of it. And ran ftw Im sure he would be well into tens. Big deal. Apples to apples same track same day I spank that *** without even a converter and less mods than him
#43
Ohio your bs gets worse daily like most bros since the 6th gen came out.. Weird bolt on bros can't get in the 11s here or back at Cecil unless They are door panel less tin cans. That is why the owners go power adder because they realize na can't do what intern b.s. says
#45
#46
7 Second Club
Oldie but a goodie...
#49
#50
7 Second Club
#52
All slower than my basically stock a8 car with drag pack.
An E85 tune a8 drag pack 6gen will put a serious pounding on an exhaust and cai only s550
11.4 with just those mods? The fastest m6 s550 on the entire forum is 11.0 and he was in a mineshaft and FBO. You only went 11.2 fbo.
And you talk about GM hiding mods lol
#53
FYI.... I'm tied for the second fastest bolt on stock converter car in the country and I've been out one time with the setup untuned and short shifting in 80f. A car with intake and exhaust bolt ons is a fortune ? Huh... ok
You act like I'm done... you ready for some crow when I run tens ? Where are your slips ? You got a big mouth for having nothing to back it up
#55
7 Second Club
#56
Actually it proves that a much better 60 is possible. If you or whoever didn't put that gay music in the vid you can clearly hear the car stutter in 1st gear upon clutch engagement. ........so yea and
#57
And it seems you're saying a coyote > 5.2poo.
I personally don't think even the newest coyote will run with the 6gen. If it does then it will also outrun the gt150s. And i don't see the base v8 outrunning the optional full zoot one with 60 more hp and more tq.
#58
7 Second Club
#60
You have even more mods with no track times. Epic bro. Thanks for the input
