OJ vs LS3 Vette
So far I'm happy with it. Its been in stop and go traffic for 30min in 90* heat, beating on the car with the ac on for a while and the temp has never moved. My tuner said I should even be able to road course with it. It was pricey, but that's the NA game.
i emailed meziere asking about one. As usual the Camaro aftermarket is lacking compared to yours. The lt1 been out since 13-14 and I can’t even find one smdh.
are you running an overdrive alternator? I would be just a bit worried because I have an under drive crank pulley now too
Good Kill! You have and EWP? well regarded mod right there. Did you decide on what lithium battery you want to use yet? Sucks for him to have a stock running Vette thats modded LOL.
Yes I now have the pump, seems to be working good so far. Have not decided on a battery yet.
#32
https://youtu.be/FWwD7ujbbfc
GMPP Cam, z06 exhaust. Friend of mine, he just bought it with those mods already. 20 roll per his request. It doesn't have ported rawkers, triple disc clutch, gears, ewp, tape, small battery, so its definitely not proper.
because if it were proper it would most definitely resemble that vid.
https://youtu.be/ViifpGgY58g
https://youtu.be/51KKG58uxLw
Here are some more from the night. Civic is a 9th gen, 5858? turbo, around 400whp. WRX is built with a 6466, ran 10.0 or 10.2 on more boost, was on 30psi for those runs.
he probably had the ewp at 4/20
#33
what did it run you?
#34
#36
example of a proper c6 ls3. That one for sure wasn't
https://youtu.be/4ghHGokJaVk
Well bet that wrx really got your trapulator working.
#38
