Amag fatness vs some stuff
#61
The lie is on you once again. Notice how i said 12~. That little squiggly lines means + or -. So mr **** reader i can see why that would be a issue for you to figure out.
Don't stip to win. Just cause feather duster crew tries to make it fashionable that don't mean it is.
#63
Thanks for proving my previous point, pinhead. Lmao
#64
What? That duhg thinks he's the only one allowed to talk **** on peoples cars? LOL. You reap what you sow *************. I only give him what he deserves.
Jake, I said only lettuce & you fucked it up again. Go lose to 13sec cars in your nine second beast.
#65
Yes you do reap what you sow. That's why your 383 car runs like poo
that's ok tho. We'll be able to see how muh semi built 347 will run against your full built 383.
Since i ran a 10.7 I'm slightly beyond the squiggly line.....so another lie. Saying the car is chopped/hacked is another lie. It's likely nicer than yours. For sure it out performs your heavy pos in every performance metric.
I'm prettier than you and probably in better shape...so at this point you're losing errywhere to a old man.
Jake diggin up in your fart flower deep
#66
I usually respect older people. But you being a narcissist dick head puts you in another division.
#69
But why stip it? I already said my Camaro will whoop your Camaro in erry performance aspect. .....no stips
#71
I've did whole reduction.....you should be happy. Gives you less to cry on.
ls6 was just a replacement.....not like it had a stroker crank to run 12~.
#72
well i hope you have considered since my bolt on ls6 only made 45~ less hp than your 383 that my semi built 347 will probably make considerably more. Hopefully around 100~ more.
Like I've said before. Our "camaros" are completely different cars. With what you've done to your car I would hope it to be faster than mine. No stips.
#75
It just gonna be a simple 347 build. Main goal to get it rebuilt and not break the bank doing it because i want the ls7 fixed also.
Not gonna have as much compression as i hoped because of the somewhat limited choices of ls1/6 pistons available w/o goin to a aftermarket rod. So selected a piston with a nice ring pack and put some gen4 floating rods with them. That's the bottom end.
Top end will be some gmpp cnc ls6 heads. Don't know what cam.....i have darths 540whp cam. Might use it idk. Hammer has a cam i could use also. The one that was spec'd for a sbe 6.2. Darth also spec'd a in between cam for me. My buddy chris builds race engines for a living. Gonna see what his cam guy says also. He built a 630crank hp 346 with stock 243s.
I would like to pull gears in the 7500-7800 range which seems reasonable to me since the ls6 seen as much as 7300. Pretty basic ****.......not a complete build like yours.
#79
