should a stock ta pull on an evo??
Originally Posted by MillaTK
On a side note, probably not appropriate, but oh well... Is it possible for an AWD car to do a wheelie?
I would like to see one do a burnout with all four tires
Originally Posted by enisguy
If I drove an Evo I don't think I'd ever run from a roll, uness it was with a Honda.
It works both ways too. Guy on our local messageboard has an Evo and a guy in an SS camaro pulled up next to him at a light and started revving on him...while it was raining!
Needless to say it was quite the raping, and hopefully taught the f-bod a lesson in traction.
Of course, what idiot wants to street race in the rain anyway?
Originally Posted by apathy
Yeah but with those stock turbo cars, it's all too easy to drop a little $$ and get big results. Gotta watch out for the modded ones.
Originally Posted by Kckid
I actually think the LS1 responds to mods just as well as evos and stis do. I could be wrong but other than their initial boost control, bov, wastegate etc. they start getting expensive to go fast.
Sort of true, one of my really good friends has an 03 EVO. He is running 23 lbs of boost, new cams, larger piping for the turbo/intercooler, down-pipe, !CAT, Cat-back, intake, 2000 dollar ceremic clutch (the stock one is sh*t) and tuning. He walks all over my LS1 from a roll. He is running consistent 12.3's at 115 mph. He dynoed at a peak of 335 horses. He launches at 4500. I have helped build this car, and it is really sick for the stock turbo and internals. And getting all 4-wheels to spin is a lot of fun
. Exsaust and intake piping would be the basic bolt on just as it is for LS1. That and an ECU reprogram so it does not run pig rich.Anyway. My overall outlook is this: Bolt on basics on 4g63 equiped cars tend to make bigger relative gains than on LS1 cars. My DSM is basicly stock save for a mildly ported turbine housing and 02 sensor, full exsaust, and 14 psi boost as opposed to about 11 psi stock. The diff between me and stocker is very very noticeable. At this altatude (5000 ft+) its a huge difference realtive to NA car gains. BUT, the LS1 is going to make the really big power a lot easier down the road. And if you throw spray into the mix it goes more in the LS1s favor by a quite a bit too. Just look at what C5R motor put down in road race trim. Thats a motor putting that power down for endurance races. You wont see so many 4g63s do that as continously and reliably for that kind of punishment.
I've ran a couple Evo's in my area... those things aren't sluggish from a roll with the right shifter lol... Intake, TurboBack, Boost Controller, and Turbo Timer, those things aren't EASY to beat... my friend stayed side by side with my a4 til I hit 3rd gear... then it wasn't a race, but he put up a damn good effort til then.
I mean, $2000 to go from 200hp to 300hp in a DSM. That's $2000 for a 50% increase in hp. SR20DET, 2JZ-GTE, 4age...Real easy to make a huge leap in hp.
The nice thing is, the LS1 starts out as a monster.
Well the LS1 is responsive to mods. But if you ratio the cost to hp, the little turbo 4 bangers are usually on top.
At higher speeds, the AWD, coupled with being shaped like a brick, will make it hard for them to keep up.
Yeah, but don't forget about Ford's new Cobra now also... I hear some people calling it "the Domestic Supra". 2 grand gets you from 360 rwhp to 500 rwhp.
Originally Posted by Sparetire
AWD is not the bogger people make it out to be. The most common myth I have seen online is that people seem to think driveline loss is a set % no matter what your power. But its really a set amount more
*snip
is significant, but not as much as gearing and aerodynamics from a roll. And the overall percentages get closer as power goes up. Of course, the T56 wil also not break as much as power goes up
*snip
.If you have the exact same car with AWD and F/RWD in it (GS-T and GS-X for example), the AWD will jump off the line, the F/RWD will pull from a roll. 'Tis the nature of the beast.
Yeap. Common thread? FI from the factory. If it's built right, it's straight nasty!
Originally Posted by Skarecrow
35mph? do you have 2.73s? i've got 3.23s and 35mph is my worst dead spot. the car kicks like a mule from 25mph though.
3.23 A4 stock shift points are:
1-2 35MPH
2-3 85MPH
3-4 135MPH
Originally Posted by danno_SS
You don't downshift to 1st at 35mph with 3.23s.
1-2 35MPH
2-3 85MPH
3-4 135MPH
1-2 35MPH
2-3 85MPH
3-4 135MPH
my trans points with 3:42s is
1-2 42mph
2-3 79mph
3-4 127mph
According to the gear chart 3:23s is
1-2 44mph
2-3 83mph
3-4 135mph.
The LS1 4L60E is eithere geared a lil more..or just because the RPMs are higher...3:23s on LS1
1-2 46mph
2-3 88mph
3-4 142mph.
Info gathered at http://www.f-body.org/gears/
