Street Racing & Kill Stories Basic Technical Questions & Advice
predictions please
Old Jan 18, 2026 | 01:26 PM
  #41
MuscleStang's Avatar
Originally Posted by HioSSilver
Your mom's a dude
I have you in your feels again… 2800lbs…. “No i swear i ran a 1.2 at 3,300lbs with 420 torque” lolololololol… 420 torque after a decade of “tinkering with it” is absolutely garbage….11.0 at 2800lbs lmao wow
Old Jan 18, 2026 | 01:32 PM
  #42
HioSSilver's Avatar
And once again you've been proved wrong fuckboi
Old Jan 18, 2026 | 01:35 PM
  #43
ufffffff slow junk needs to be at 2800lbs…. Boring build. Nothing but covered holes and hinges that needed to be lightened per your old posts lmaooo
Old Jan 18, 2026 | 07:43 PM
  #44
01CamaroSSTx's Avatar
Wouldn't you want the lightest car you can get for a drag racing application? What's wrong with having a good power to weight ratio? All I hear is whaa whaa whaa..Sounds like someone being a cry baby if you ask me.
Old Jan 19, 2026 | 10:12 AM
  #45
HioSSilver's Avatar
It may not even be that they don't believe that.......it's they don't want to believe me and that they really have no ******* clue. Any na furd that's remotely fast the car car is completely ******* destroyed.
Old Jan 19, 2026 | 12:15 PM
  #46
LSux's Avatar
Define power
Define torque
Tell me what a shift point calculator is actually calculating
Let me know when you can quantify torque without a calculation
Old Apr 24, 2026 | 08:14 PM
  #47
ULTIMATEORANGESS's Avatar
Did you run him?
hes added A cam but i decided to run anyway.
he got me by a bit 60-145.
Old Apr 26, 2026 | 12:46 PM
  #48
HioSSilver's Avatar
Originally Posted by LSux
Define power
Define torque
it's called a load sensor bitch boi
Old Apr 26, 2026 | 04:38 PM
  #49
LSux's Avatar
A load sensor doesn’t “quantify torque.”
It measures force.
Torque is that force applied at a radius.
Which means… you still have to calculate it.
Even on a loading style dyno, you’re measuring load at the roller and converting it to torque based on drum radius. That’s literally a calculation.
So you just proved my point.
Again
There is no way to quantify torque without a calculation. You can measure inputs. You can’t skip the math.
And that still doesn’t answer the rest:
Define power.
Define torque.
Explain what a shift point calculator is actually calculating.
Or keep throwing out buzzwords and pretending that’s an answer.
