Killed by a C5
) Wasn't going for reaction time, just trying to launch the car as hard as possible.R/T----.342
60'-----1.639
330----4.796
1/8----7.499
MPH---89.45
1000--9.884
1/4---11.905
MPH--111.78
I was pretty happy with the times. Car was running pretty damn consistant (worst time was a 12.16 with 28lbs in the tires and no burnout). I was even more impressed by the 60-ft's I was cutting. I am running on a 17" M/T drag radial and was dead-hooking. Even pulled the front left off the ground
Those tires are bad-***
Bone-stock suspension, gotta do something about that. I was having a bit of a "problem". When the car was shifted to 3rd, it seemed to drop off a couple hundred more rpm's (definately wasn't in the powerband.) than 1-2 shift. I don't know if it is the 3.42's or not, but I raised the 2-3 shift by 200 rpm when I got home
You can hear it in the vid....sounds like I'm letting off. With my 7.499 1/8, I should be in the 11.70'shttp://www.corvettekillstories.com/p.../cecil_011.MOV Last edited by kjmdrumz3; Mar 13, 2005 at 10:47 PM.
You are correct about the car. AFR heads, 224/228 581 588 cam. It runs great! I've only had it to the track once. It ran 11.86@ 124 with a 2.0x 60 foot on the stock tires.
I didn't mean to steal the jump. You probably couldn't see, but your buddy in the Vette took off first and I was just going with that.
Your car looks and sounds good. Maybe I'll see you around again sometime.
you should come hang out with us sometime. we are usually at Ann's on friday and sat nights at 9 pm.
nice *** C5 by the way! sounded GREAT!
get a chance check out http://www.CorvetteKillStories.com
I will definitely have to hookup with you guys. Maybe I’ll see you this weekend.
