478rwhp '03 Cobra goes down
#101
Originally Posted by Shackleford
Well, obviously, you would stengthen the rods and so forth upon installing a FI setup on the LS1. Regardless, a NA LS1 > NA DOHC Cobra 4.6L. That IS my point. When you give an engine FI, it changes the plausibility in a comparison to another engine. So, you compensate either way and go from there.
#102
Originally Posted by WhiteTXMach
So now your talking about a built LS1 vs a stock 4.6L? Sure, go ahead and change what we are talking about. First it was FI LS1 vs FI DOHC. Now its N/A vs N/A. Your argument is STILL weak.
#103
Wow. You totally missed my point.
I see your point. The heads comparison is wrong, but the Cobra's basic design for forced inudction is the INDISPENSABLE part. Forced Induction is an external alternative to supplying oxygen to the cylinders. There is a "difference" when you are comparing NA and FI engines.
Upon discovering my POINT, you validated my post. NA LS1 > NA DOHC Cobra 4.6L
FI LS1 > FI DOHC Cobra 4.6L
#104
#105
My comparisons are a FI LS1 versus and an already FI Cobra and an already NA LS1 versus a "detuned" NA DOHC Cobra 4.6L. The point is to allocate congruity in the way the air finds its way into the cylinders.
#106
How are you NOT wrong? A F/I LS1 will handle how much boost without blowing up? A F/I 4.6 Cobra block will handle how much boost? Your argument is weak.
#107
Originally Posted by ws6sojuiced01
Compression has alot to do with the boost ability. ive seen ls1s run in the 10s on stock int on other means of power such as nitrous. the cobra can handle more boost cause it was built for boost. To bad they didnt build it for traction.
#108
Originally Posted by unit213
I thought I'd heard every excuse in the book...until I read your post. "But Cobras have a blower, they should be faster...Mach 1's have 3 cams and 32V's"
Is it really that hard to grasp the concept that each motor is setup differently? Why do we continuously have this arguement? It's pointless.
Ever heard of a Mach1? It only has 281cubes vs. the 346ci LS1 and it runs neck-and-neck with LS1's in bone stock trim. What's your arguement now?
EDIT:Honestly Unit, "the" arguement is definitly old. I really could careless. I was just making a small point. I grow tired of the GM guys excuse of FI, and I grow tired of Ford guys excuse of ci. That is all.
#110
Thats funny, none of the local LS1's impress me much either.
where are you at in texas? you said up north dallas right? cause i know a few guys that would be up for some runs, you on the sauce for some green!
anyways, PM me if you want, this thread is ******* done
#111
Administrator
Gray...set him up with a few 800rwhp LS1 guys.
#112
You've got to be kidding. You're making no power and you make a comment like that?
i got a PM from him... and it is all under control
