allngn_c5 hitting 190 + going to work VIDEO
#61
Thanks to all those who commented, both good and bad. I am shocked that so many people looked at the clip, over 1000 and counting. Thanks to everyone and stay tuned for the next vid.
#62
Originally Posted by Vendetta
You won't pull any more in 6th gear than you will in 5th at top end.
Originally Posted by allngn_c5
Check with LG on that, you are incorrect sir.
Read my post about 5th and 6th gears.
Unless one has a very high horsepower car (700 or 800 rwhp) our .50 ratio 6th gear (you have the same as us with your 3:42) just requires too much torque down low to pull. I know from personal experience.
Ask LINGENFELTER about that
And if you STILL believe you can do a top speed run in your current 6th gear on your current set-up . . . by all means . . . take it to 190 in 5th and then drop into 6th . . . let us know what happens
#64
Might as well just hit the brakes.
#66
jesus i feel like i'm playing need for speed. that thing sounds badass, man.
if you decide to do this again, put a little seafoam in your brake booster. cops can't pull you over if they can't see you
#67
Thanks, but I was running out of straight away so I had to let off, put light pressure to the brakes and hit 4th on a downshift and add brakes to make that curve, I've done the run over a thousand times. According to LG Motorsports they have done several cars exactly like mine with full aero kits and an extractor hood that have done 210+ mph. I can't wait for my aero kit, wouldn't want to fly away. LOL !
#68
If he actually hit them, which is not recommended at those speeds, they would be flame red; mine were when I hit them hard at 160
At extremely high speeds you don't wanna hit the brakes right away. If aggressively applied, you could inadvertently swing the rear end around . . . this would be bad.
190 . . . 200 mph . . . slowly lift off the throttle and allow the tremendous wind resistance to slow you. Then I'd recommend applying serious throttle at 175 or so; with aggressive brake application at 160
I like allngn c5 . . . we have the same psychotic illness
#70
Originally Posted by erikthegoalie
doug bad *** vid man....
i found myself gripping the arms of my chair man
Hey Erik, I was going to ask how your car was coming along, but I saw in your sig H/C coming soon. Glad you liked the vid, how was your visit to Central America? Later Bro.
