Z06 vs Murcielago
You do get around, Oz, don't you. Nice to see props given to the Murci driver who actually has the nuts and skills to thrash his car.
Quite a few other interesting runs from that day.
Agreed.
This was only the tip of the iceberg. Check out www.fulltiltlife.com for the rest of it, it will be part of a DVD featuring some really exciting races.
FWIW, heres a vid of a stock ford gt (put down upper 4xx, lower 5xx stock) against an intake/tune otherwise stock c6z...
http://video.google.com/videoplay?do...919895&q=c6z06
Ive also seen a video against a gallardo (maybe murcialago, not sure) and from a roll the stock c6z put 2 cars on it.
I can't see the video. When i click the link it says on the top in red print, "This is a private video. If you have been sent this video, please make sure you accept the sender's friend request."
What is that about? How do i view the video? It seems like no one else is having problems...(weird)
Same problem here
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
#32
#34
Originally Posted by Car RamRod
how does a gallardo fair against a murci?
Murcielago has a 580 HP v12, instead of 500 HP v10. Weights about 3600 lbs, Where as the Gallaro weighs significantly less at 3100 ish.
#35
#36
Lambo just dropped hte Murcielago LP640.....640HP AWD.....sign me up NOW
