another 5.0 kill..
Lol, seriously. On a tire I might hit a mid/high 13, but it still traps under 100mph. Lame. I gave up and went LS1
Dynoed the motor, powerband is good, compression is good, ect. so its not a mechanical problem, the heads just suck.
Here is an AFR headed 302 with an E cam and GT40 intake, ect. ect. ect.
286whp
http://www.musclemustangfastfords.co...rd_mustang_LX/
Here is the dyno sheet (bottom of the page)http://www.musclemustangfastfords.co.../photo_34.html
244whp out of my GT40P heads and 17" fixed flex fan wasnt bad after all...
Example: my friends full weight 91 GT has 3.55s 18 inch deep dish bullits, GT40 intake, x pipe and flows (probably pullies, I will ask) ran a 14.1 at 100 on the 18 inch street tires of course.
That is normal.
Your car sucked
your setup sucked
your driving sucked
I dont know you to be able to tell how bad you suck.
I made 295/321, my friend made 299/329, and another 302/325. the only difference between our setups is the headers and intake manifold.
That much power with 200 dollar heads with 150 dollar springs and retainers is no joke.
These heads ported can flow near 240/200. AFRs 165s flow 252/190 out of the box. They wont touch a ported AFR or trick flow when you want to make power, but its a hell of a junk yard head.
I have added ballast to compare my car to original weight at the track. It did not slow down THAT much. Almost 2 mph. I know a few 94-95 guys with convertible GTs. one weighs 3650 with his TKO and runs 12.2 at 112 on nittos dynoing 304/331. The other weighs 3900 (he is huge) runs 12.7 at 109 on nittos dynoing 311/340. no pro drivers. Just normal guys that dont even powershift.
That is normal.
Your car sucked
your setup sucked
your driving sucked
aluminum GT40s suuuck when you look at how they act and the average flow numbers, i woudl take a set of Ps over GT40Xs any day. believe it or not. I know that ford crate motors are terrible in the horsepower department. I usually dont see their crate 302s make more than 285rwhp.
286whp
And who in the hell would put an E cam and GT40 intake with a pair of AFR's??? No wonder it made 286rwhp, that looks like a typical "i dunno how to match the parts in my combo" build.
5.0's don't suck when you build them right, your's just sucked cause you had a **** setup
. The Best V8 Stories One Small Block at Time
.I would have around 270whp had I not used a fixed 17" fan and had all that extra rotating mass of 4.10's and a TKO500.
286whp
.Hell I'd put any amount of money he wanted against my STOCK PISTONS, full weight, stock transmission, mild, daily driver 5.0 against his mighty LS1. Hell I'll even leave the bottle sitting on the staging lane to the side of the water box.
Its a shame he doesn't live close by. Oh well...some 5.0 will put him in his place. Won't take much either.
Its a shame he doesn't live close by No, I think it is a good thing because I am tired of internet warrioring and have lost all patients for those who want to call me out. I would not be able to treat you in what I consider a mature way if I met you in person. Oh well...some 5.0 will put him in his place. I don't even race the LS1 except impromptu romps on it every now and then. It is just a decent daily driver that I want to last through college. Won't take much either.
Here is why I do not respect the 5.0 as much as I do the LS1.
The block is SENSIBLY limited to 450whp
There is no 15* head within a SENSIBLE price-range
It is limited to 347ci displacement
It is not cost-effective to get power out of past 300whp. unless you go FI and that has it's own set of issues.
I love it when people knock my engine-building skills. I bought a pre-assymbled crate motor that got great reviews both from other customers, MM&FF rags, and random internet sites that I came across. I payed $3200 for a brand new 340SAE Gross hp motor. That isn't too bad. Made 244 to the tires, that is 280BHP Net. Not bad for iron heads and a poorly selected cam shaft (who knows why they put hte X303 in. I sure dont. I guess Dennis Hillard just ran CCM into the ground after the company had been doing GREAT for 25 years. I heard a lot about that jackass AFTER! I had it in the car.)
Crate motors (I found out the hard way...) are rated SAE Gross. Not SAE Net. Keith Craft cleared that up for me after CCM closed and I wanted info. Nice company/person!
If your AFR headed 5.0 dynoes over 320whp then I will be suprised. Keith craft usually gets around 310-330 out of his AFR/Brodix/Trickflow headed 302 motors and that is with a cam-shaft ground to his specs by comp and with a lot of other stuff done in-house.
sorry to the original poster.
. Atleast you have a car now that it doesn't take alot of thinking for it to go pretty fast, just don't do any big mods and you should be good to go man
we know about the block
Head choices are fine, you pulled a buzz word out of your magic hat.
Cost effective 300 hp?
My entire bolton setup:
typhoon intake - I literally made money doing this somehow. (300 Came with TB and FPR fox computer and harness. sold harness for 80 and fpr for 40 and will sell computer for 75)
gt40Ps - 200
lunati springs and retainers- 158
comp OTS cam- 175
1.7s RRs (avg 100 used)
MAC LTs - 100
Prochamber- actually got this for free from a wrecked car
Spintech mufflers- 100
I run a fox Tb conversion. free but needed EGR delete plate - 16
24 lb inj and 77mm Maf (200 used)
Pullies came on car (100 bucks)
gaskets head bolts- 120
case of beer and a few pizzas along the way- 50
knowing what you are doing when selecting a combo - priceless
I know AFR custom grind cam guys that make as low as 292 (due to stock exhaust and only 19 pound injectors) I have friends that make 330 with an off the shelf comp cam and 165s. I have seen trick flows and AFRs make 290+ with a stock cam installed straight up. And AFR 165s do 304/340 at the wheels on a 93 cobra with the stock cam retarded 4 degrees and the lower intake ported to closer match the flow of the heads.
My main rub with my 5.0 is I found out (too late in the game) that if I wanted the power I was after, I needed AFR heads. Instead of pumping MORE money into an aging car prone to other issues, I just got somethign that is slightly slower than it would be with AFR's but has no other major issues.
I agree that 5.0's can be fast, but the LS1 is quickly becoming the "new 5.0". I like the 5.0's for what they are. They are easy to work on and fun cars, just irritates me that everyone thinks they run low 12's when most barely nip them, if that. The 5.0 has a LOT! of stigma surrounding it and 90% of it is unwarrented. Just like the bullshit about WS6/SS cars being "so much faster" than regular Z28/TA's. It gets on my nerves.
