SRT10 VS the Entertainer
Originally Posted by Killemall
Even Gus TOLD YOU SO. He was right there man.
HMMM... If i remember correctly GUS told you that you were pulled by a 1/2 car....And he was being pretty generous with that IMHO...
As for my WIFE as you say...we tried and tried to tell you the OBVIOUS truth that you got pulled to the point that we couldnt even see you any more...We were both looking right at you as you fell back LOL...
But your the kinda guy who dosent like to admit defeat...
trust me..The Beautifuls car pulled me and thats how i posted it..Your car didnt..You got pulled..
If you wanna say you blew by me after I let off not to hit the traffic that you almost ran into then more power to yaa..
By the wayyy..Your the BLATANT LIAR...LOL..cas there NO WAY IN HHELL YOU DIDNT SEE MY CAR PULL YOURS...
I wasnt even gonna post this story as I thought we were gonna go again..Then you just dissapeared after we had already agreed to run from 70-140..
HowFast told me you went to go get your drag radials..WHY WOULD HE TELL ME THAT???
BTW....Outta respect dont mention my wife in any of these post again. I get very very very defensive if I even think that someones saying anything negative about my wife in any way what so ever.
And out of respect ill do the same for you...
Now where were we..thats right..You wanna handle this ASAP right..
I dare you to bring your pump gas 21 pound supra on street tires back for a rerace
As discussed.......A PM(not a call) will be sent to you to confirm the "rematch."
A video will be taken so there will be no inaccuracies on either side......
Rules of engagment will be layed down before the start.
Gus//
Gus//
Originally Posted by FEARSM
LOL..you are truly a piece of work. The only reason you didnt see me because I was right beside you in your blind spot. Not sure why Gus told you that but he was wrong and Gus is not me. I never told him that and he will attest to that fact. Now you try to limit me to street tires and low boost. You know the car will spin so thats the only way you have a chance. Pathetic. Why do drag radials matter if we are going from a roll? What are you scared of? I will be out on street tires and pump gas. I wasnt running 21 psi. I was running 1.48 cm/kg which is only about 18-19 psi. My BLITZ boost controller does not show psi.
YOU DO REALIZE THAT MY CAR HAS 492 RWT SAE RIGHT??? THATS PROBALLY A BIT MORE THAN YOU HAVE AT 1.4 BARS..SO GIVE UP THE TIRE SPINNING STUFF MAN...MY CAR HAS 492 RWT SAE AT ONLY 4000 RPM'S..
YOU THINK MY CAR WONT SPIN IF I HIT IT HARD AT 50 MPH...I can spin them at will in third gear at 80 mph
Dosent sound to baddd...Now where's that phone call
HP yes...TQE nooo///
A 600 rwhp supra will make around 400 rwt..Come on man..Ive seen more than enough dynos of Supras to no that I have wayy more tqe than you..
And yes..For the record I can spin at 80 mph in third gear no problem..Done it manyy times while I was practicing to rerun RSKY from third gear pulls..
The point is that i could get my rpm's up high in a roll race and launch hard as well..But with 560 crank TORQUE all I would do is spin as well..So I baby it...
BTW....what is your auto Supra putting down powerwise with 1.4 bar of boost and pump gas..
I could have sworn that with 28 pounds plus NOS you were only around 700 rwhp???
Am I thinking of some one else?
Enlighten me to what you dyno with low boost (1.4 bar) and no spray/meth please???
#32
I have no idea really because I never dynoed at that psi. At 15 psi which is less than 1.4 bar I made 550 rwhp. That's pump gas, no meth.
Honestly, you have no clue about Supras so please dont try and tell me what they dyno. That all depends on the turbo. When I had the 63mm turbo on my 6 spd car I made 636 rwhp and 599 tq. The dyno is at BSM and I am sure Body still has it on file. My nitrous dyno was done when I had a boost leak. I will be redynoing soon. Like I said before, the numbers on an auto arent the same. Apparently you dont get that part too well.
#34
HMMM..Those are the highest rwt to rwhp ratios Ive ever seen on a Supra by far..
So we shall see as soon as I get that phone call
#35
There are 104 MKIV Supra dynos on this site. There are 37 listed in the 600-700hp range. Of those 37, every single one made over 550rwtq.
http://web.archive.org/web/200301270...rbo_detail.htm
#38
Is it? Thanks for that. Do you have a conversion chart?
"You more than likely only need to worry yourself with "kg/cm2". That is the common metric measurement for pressure and what is used on almost all of our automotive "metric" gauges and meters. Below is a chart that converts kg/cm2 to psi.
Kg/cm2 value = equivalent in psi
0.50 kg/cm2 = 7.11psi
0.55 kg/cm2 = 7.82psi
0.60 kg/cm2 = 8.53psi
0.65 kg/cm2 = 9.25psi
0.70 kg/cm2 = 9.96psi
0.75 kg/cm2 = 10.67psi
0.80 kg/cm2 = 11.38psi
0.85 kg/cm2 = 12.09psi
0.90 kg/cm2 = 12.80psi
0.95 kg/cm2 = 13.51psi
1.00 kg/cm2 = 14.22psi
1.05 kg/cm2 = 14.93psi
1.10 kg/cm2 = 15.65psi
1.15 kg/cm2 = 16.36psi
1.20 kg/cm2 = 17.07psi
1.25 kg/cm2 = 17.78psi
1.30 kg/cm2 = 18.49psi
1.35 kg/cm2 = 19.20psi
1.40 kg/cm2 = 19.91psi
1.45 kg/cm2 = 20.62psi
1.50 kg/cm2 = 21.33psi
1.55 kg/cm2 = 22.05psi
1.60 kg/cm2 = 22.76psi
1.65 kg/cm2 = 23.47psi
1.70 kg/cm2 = 24.18psi
1.75 kg/cm2 = 24.89psi
1.80 kg/cm2 = 25.60psi
1.85 kg/cm2 = 26.31psi
1.90 kg/cm2 = 27.02psi
1.95 kg/cm2 = 27.74psi
2.00 kg/cm2 = 28.45psi"
Sounds like some good times in Hawaii
