Street Racing & Kill Stories Basic Technical Questions & Advice
Which slicks to use on public/dusty roads? Can't match AWD cars launch
Old 09-27-2012, 11:01 AM
  #101
Vetal's Avatar
I don't think these will work better than full bias-ply slick. I ran down to 10psi in my MT Drags, when they look almost flat
Old 09-27-2012, 11:05 AM
  #102
2SSARME's Avatar
Run slicks and call it a day...
I run them down here in Panama and they work. I run 28x10x17 Hoosier drag slicks at 20psi on the street with my 21¨rims up front.
I was out launching just about anything and everything. Slicks get eaten up fairly quickly and they suck for daily/rain but they will give you an incredible launch.
Didn't read enough but you're going to need a full drag setup to not break anything. I went with just about every single rear and front suspension piece from BMR and the car has really turned into a monster.
My car is sitting at 630+rwhp and 600+ rwtq and I was hooking in 1st. With my roots I get full torque at 2.5-3k rpm. So you shouldn't have a problem hooking if I could do it with noticeably more power and torque.
Old 09-27-2012, 11:12 AM
  #103
Vetal's Avatar
I run 28x11.5-15 slicks, 12-bolt Moser rear, it's not gonna break. I don't understand how you dead hook on the street though with 600whp What's your 60', ET, mph in 1/4?
Old 09-27-2012, 11:18 AM
  #104
2SSARME's Avatar
Because the car is heavy. 4000lbs helps you hook. No times because we have no tracks down here. When we vboxed it I was pulling 0-60mph in 3.6 but I was spinning.
To dead hook I have to burn them. Here's a video showing me dead hooking. The car filming is a modded mid 11s 335i. Note he jumped on the 2nd honk.
And here is against a carrera GT from 5-10mph. Filming from my car.
And a low roll
Old 09-27-2012, 11:37 AM
  #105
Vetal's Avatar
Hmmm, that's a bit "not enough" for 600whp dead hooking You have to get to the track
Old 09-27-2012, 11:42 AM
  #106
2SSARME's Avatar
It's not rocket science. Good drag suspension, weight and slicks will dead hook a 600rwtq 5th gen.
What suspension are you running on the back of your ta? No reason you shouldn't be hooking on slicks, especially with a turbo, which won't make torque like my maggie.
Old 09-28-2012, 01:30 AM
  #107
Vetal's Avatar
I don't know what weight distribution yours have, I suspect not 50/50 too, but my has 56% on the front, I suspect this doesn't help with traction.
In the back - Spohn LCAs, LCA relocation brackets, UMI torque arm, WS6 shocks/springs.
You see, problem is not the street itself but our local 60-year old track, which is much more slippery than normal asphalt on the street. That's why I seek for some unusual solutions people don't have to use on US drag strips. 8-second (in 1/4) cars can only do 6.5s in 1/8 when they come here. So I need some extraordinary weight transfer to use the power here I'm thinking about raising the nose maybe another 1-2" for the races...
Old 09-28-2012, 01:46 AM
  #108
2SSARME's Avatar
lol. Here we lose about 1.5-2sec on 1/4 mile when you are RWD. I know my mechanics 140+ trap stang was running 11s and was crossing the 400m mark spinning.
Sometimes there's only so much you can do. You're going to spend and spend money and never going to be where you should. Some factors are out of your control. Make it a street car and call it a day. Forget about the track.
That's my advice.
Old 09-28-2012, 01:54 AM
  #109
jimbos'ss's Avatar
haha I run at GRW in germany so I feel your pain, On ET streets cooking the hell out of the tires, my best 60 ft is 1.9. So far my car with a baby cam and LT's has gone a best of 13.013. At a real track i'd be doing that almost stock.
Old 10-03-2012, 06:18 PM
  #110
Vetal's Avatar
Originally Posted by jermzz
everything looks ok for the most part except your shock / spring setup. Thats huge. Your shocks are not made for drag racing at all.
Ditch those, get some hal qa1's all the way a round with 275 front springs and put stockers in the back. Also might wanna pick up a drag bar.
The qa1 setup will allow you to adjust the shock pressure at all four corners and give you ultimate weight transfer which is tractions best friend.
Tonight I ran some tests with my new front Strange Single Adjustables and was a bit disappointed. 60ft remained the same 2.0 as it was with Bilsteins, only once I got 1.96 and couple of 1.99s... Tested all this with my Gtech Pro
Quick Reply: Which slicks to use on public/dusty roads? Can't match AWD cars launch
