Street Racing & Kill Stories Basic Technical Questions & Advice
ls1 a4 racing tech question?
Old Dec 1, 2007 | 01:57 PM
chevy0128's Avatar
Default ls1 a4 racing tech question?
i have 2001 z28 a4 with basic bolt ons. Would it be more of an advantage for me to start my automatic trans in 1st gear if i am racing someone from a roll and then shift it when it gets to 6k?
Old Dec 1, 2007 | 02:00 PM
waterbug1999's Avatar
If I were you, I would let the trans do the shifting. Just tune it up a little.
Old Dec 1, 2007 | 02:04 PM
chevy0128's Avatar
yea i used to have a hypertech chip n i liked it alot but i had to take it out because i had a 100 shot of nitrous put in . I havent used it yet because i am in the proccess of getting rid of a spark knock, but my car just never shifts to the top of the gear. if i am rolling from 40 or 45 it shifts to second. how would you recoomend tuning it up
Old Dec 1, 2007 | 02:08 PM
Maybe raise the shift points up along with the rev limiter.
You have a higher stall in the car?
Old Dec 1, 2007 | 02:15 PM
chevy0128's Avatar
no stal on the car.. how do i raise the shift points along with the rev limiter.. i would need some kind of computer tuning...whicn would you recomend
Old Dec 1, 2007 | 02:18 PM
Yea, you would need the software to adjust shifts and what not.. My buddy did mine and he has EFIlive...
But, now knowing you dont have a nice verter on, I would do that before anything else. That should be one of the 1st things you do for us A4 guys. It really wakes up the car.
Old Dec 1, 2007 | 02:22 PM
chevy0128's Avatar
well what should it be set for a bolt on z28 at and how much will it cost with install
Old Dec 1, 2007 | 02:26 PM
What does it shift at now?
As far as a verter and having it installed, it depends on where you take it. I bought my fuddle N20 verter for a nice price and put it in myslef in a day.
Serious though, get the verter and you will kick yourself in the *** for not doing it sooner.
Old Dec 1, 2007 | 02:29 PM
chevy0128's Avatar
i am still a noob at all this i just bought my car about 7k milles ago at 60k and i love the car just not the auto trans hah but what exactly will the verter do. with this help much from a roll because most of my races are from a rol
Old Dec 1, 2007 | 02:37 PM
RAGENZ28's Avatar
If it is a stock motor with bolt ons you'd want to shift it around 5500-5700 tops.
Converters let the transmission rev up to a certain rpm to keep your car in the right power band. If you have a 3600 stall converter and floor it no matter what rpm you are at it will instantly go to 3600 and pull from that rpm up.
I had a 4500 in my car so even at a stop light at 0 mph you gas it would rev to 4500.
But if you cruise you can still drive at a lower rpm, I could drive mine around at 2000 rpm.
As far as what converter you want to go with on a stock motor it's hard to say what you care more about mpg, performance racing, there is always a trade off. If you want the car to be faster I would think something in the 3000 or so area will give you a good gain in performance. Going less than that is fine too but once you upgrade and go with a bigger cam or start making power in the higher rpm range something 2500 wouldn't be as good as a 3400 or 3600 converter.
Just decide what you want to do with the car and go from there.
Old Dec 1, 2007 | 02:38 PM
60k???????
Yea, a higher stalled verter will help kill the dead spots you get with it now.. It will keep you in your powerband.
Ill check back later, I am going to go play in the snow.
Old Dec 1, 2007 | 05:37 PM
Navy David SS's Avatar
Since this is a "Drag Tech" Section and we don't race from a roll at a drag strip.. I'll move this to street racing section
David
