2005 Neon S R T 4 vs 2002 Camaro SS
with just a wastegate and 18psi about 240whp. i ran a 13.8 @ 103 with a 2.2 60ft
Good race though, the GTO moves!
it sucked ***** from a dig lol, but from a 20 or 35 kick it was pretty quick. i would usually pull stock fbodys. i races one with a lid, full exhaust, and something else small like therm. and we ran like 4 20-130s and we would stay almost dead even till 115ish then he would pull a nose on me to 130. it would prob run low 13s @ 106-108. i never ran it like that. with just a wastegate and 18psi about 240whp. i ran a 13.8 @ 103 with a 2.2 60ft
all while gettin 27+mpg lol
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
yes but what did your car weigh, and the stock turbos are about the size of a snail. srts with 50 and 60trims are runnin high 10s to mid 11s
Its not leaking anywhere. I have tested it. It has nothing to do with a leak. it starts spitting and sputtering if I turn it up any more than 13#s so I run it at 11 to stay on the safe side. I'm sure once I started playing with fuel I can run more boost. Fing 05 's suck!
#33
mine was a 05 never had to change nething to do with fuel. somethings up man, you need to go to dodge n do a diagnostic, becayse you should run more than 11 stock!
#37
#38
It's a nickname they were given when they first came out. Someone commented about how they come in such fruity colors like skittles. Then the nickname just stuck. You can go to any type of car forum (mustang, dodge, gm, honda, ect) and find posts referring to $rt-4's as skittles.
Taste the rainbow
Taste the rainbow
