Called out by 62mm FD RX7??
I'm pretty sure he has to run 116 on 20lbs and the turbo is an S362 produced by BorgWarner Turbo and Emission system (Where I currently have a job). I know the turbo extremely well, because I put it in and matched it to his motor.
With your mods and your 4.10s, I would expect 450 or slightly less. It takes aftermarket castings to see high 400s usually. Put in a 9" and that will reduce you as well.
dyno numbers and 1/4 ETs do not really tell the performance of the engine, it's all about the roll on power and the 1/4 mph.
I don't know much about import cars in general, but I can tell you 9/10 fast supras are single turbo.
ProjectD - sounds like a fun car my friend.
I'm not actually sure but I think it is a .83 a/r with a 76mm turbine wheel. Oh and I don't work at a shop. I'm just a college student doing an engineering co-op at BorgWarner. I do most of the work at my house. I install all of my parts.
Kleeborp the Moderator™
Granted, I wouldn't even place a healthy wager on the RX-7 staying together for long at those power levels, unless he is really on top of his ****.
If his car is running like it should, he should drag your *** down the road. He'll have more power and a lighter car.
