Warped Rotors
Old Oct 17, 2008 | 10:43 PM
Vicinity's Avatar
Default Warped Rotors
How can you tell they're warped? Does it make a sound when you stop? Does it vibrate the car?
Old Oct 18, 2008 | 03:20 AM
ae13291's Avatar
if there warped it would vibrate when u touch the brakes at high speeds
Old Oct 18, 2008 | 04:28 AM
Revelation Z28's Avatar
if its the front ones your steering wheel will vibrate like hell at 40+
Old Oct 18, 2008 | 04:33 AM
Vicinity's Avatar
No, rears. Rear end vibrates like hell on braking. Thought my 10 bolt was shot, further inspection, I've narrowed it down to the brakes. I read these cars have warping issues.
Going to get Brembo blanks and see if they fix it.
Old Oct 18, 2008 | 07:13 AM
Foxxtron's Avatar
Stock rotors do have warping issues.
Now, when you get Brembo blanks, make sure you pad them in correctly otherwise you'll get excessive runout due to uneven pad deposition, which results in an uneven braking surface on the rotors. While uneven pad deposition isn't quite "warping" in itself, it can lead to warping.
