Tire rubbage after LCA relocation bracket installation?
Has anyone else experienced this? That car has an Eibach Pro Kit w/ stock panhard, torque arm and control arms. I suppose the rear-end is not centered, but, how would simply installing LCA relocation brackets exploit this?
- Dustin
- Dustin
As "lemons12" said, tire size will have a bearing on this, but a better question would be this... Where is the tire rubbing the car? If it's on the right side, yes, it's probably because the ProKit springs lowered the car enough to offet the rear axle. An adjustable PHB will cure that.
However just the relocation brackets shouldn't have done this, unless they weren't 100% "square" when they were welded in place, and now the rear end is a bit skewed.
Things like adjustable LCAs and PHB can help adjust the placement of the axle. That might be a bandaid for another problem though so make sure you don't have any other issues first. Just throwing that out there though.
Might wanna try a different setting on the bracket if you have it adjusted all the way to the bottom hole. Is your car lowered?
- Dustin
To make sure the rear end has not shifted side to side because of lowering, take a plumb (string with weight on bottom) and hold it against the fender, just above the high point on the tire as shown in my photoshop pic. Then measure the distance from a point on the tire side wall to the hanging string and compare both sides (measuring from same point on tire)
If the measurement is less on the right side then you can correct this with an adjustable panhard rod. Other wise chances are the brackets were improperly installed (if it has shifted forwards or backwards in the well)
and hypercoil springs with 275 40's and it dont rub.
i would also think your rear is off center.
I carry UMI PHB's and LCA's, as well as the Fays2 Watts Link (better lateral location, axle doens't move in an arc like a PHB does). Basically I've got you covered, and we can solve this. You aren't running huge tires, I think just centering the axle will cure your ills. If you are inclined to do LCA's along with the PHB we have a few packages that combine them and get you a few bucks off.
From a handling standpoint the brackets might not be helping, but aren't causing this.
The tire will stay centered within the wheel well. I have 3 sets of rims with different tires, 215/60/16, 245/50/16, 315/35/17 and only the 315's rub along the inner drivers side. Despite being centered with relation to the car with the adjustable panhard bar, when the car turns hard, the design of the suspension pushes the whole car over towards the driver's side causing the rub.
If that's the same spot you are rubbing on or biased to one side only, then an adjustable panhard is needed. If the tires are rubbing both inside of the wheel well, then the axle is moved forward. Examine the relation of the tires with relation to the fenders to determine if the axle has moved forward.
Again, your issue is very, very simple. It's your PHB length. It's too short because of the lowering and effectively pulls the body to the side vs. the axle.
You should check the measurements like I said. More than likely you will need an adjustable PHR. Just go ahead and check first. Checking this will also familiarize yourself with how to get the rearend centered laterally once you do install an adjustable phr.
