BMR Spring Question?
Definitely recommended, I've had eibach as well and like my BMR's much more. I got my set from texas speed a while back along with some other goodies.
I am fairly certain that all of our distributors have ran through their stock also.
We still need to hear back from 1 or 2 distributors before I can defintely say this.
Feel free to place your order for the new springs now. BMR does not bill your credit card until the springs ship. Also, there is no cancellation charge if you cancel your order before the product ships.
They are powdercoated red by the spring manufacturer. We would have to strip the powdercoat, sand blast the springs, and then re-powdercoat them black hammertone. We rarely use our strip tank, so we would have to heat up the tank just for these springs. Then, blast them. Then, re-powdercoat.
If you really want them in black hammertone, call Dennis and I'm sure we could work something out.
I'll be ordering this week! I have run (are you ready?): stock, 1LE, LS1 Pro-kit, LT1 Pro-kit, H&R's, Hotchkis, etc. I then used coil-overs to run a lot of other rates primarily in front, but also in the rear. 400, 450, 500, 550, 600, 700, 800, 900, 950, and even a few times 1000 and up (yeck). In the rear I've been though V-6 stock, Z28 stock, 1LE, Pro-kits, Hotchkis, 100's, 125's, 150's, 175's, 200's, and 225's.
Interesting to see that BMR is changing their springs after all these years.
Second i am driveing a F-Body with the check engine word(not the little motor)so my car was intened for the USA. also GM is in the USA.
i don't mean to get all patriotic but have a little respect for American Goods.
alot of gm stuff is made out of country but acembled in states.
GOD BLESS THE USA and the goods made here by hard working AMERICAN Citizens.
so to hijack. but to the thread
I like the USA as much as anyone. My springs are not made here, and I don't claim they are. There is but two reasons why they aren't. Because I wanted certain things to be part of my springs and could not get that here. The tight QC on rates and heights, and the material. That's why the springs are made in Germany, and that's why we often endure such long waits. But I won't compromise on what I want.
The material used to make my springs is a alloy that Vogtland makes called VVS and that is a propietary alloy. It is theirs, and unless somehow BMR has moved Germany to the USA, the new BMR springs are not either made in the USA, or not the 'exact same' material.....
I don't know why BMR chose to change their springs after all these years, but would be curious to hear. If 145-170 rear right before, why not now? As for the weight of the rear spring. It'll be hard to weigh less than mine. I use a minimum amount of metal for the springs, we don't run more windings than we need to hold the spring in place. We also use fewer coils than any other rear spring on the market in the working range. And in fact a set of my springs is 27 pounds in a cardboard box.... The rears are only about 4 pounds each. The majority of the weight is saved on the front springs as they use much thicker wire, and are much heavier than the rears.
And let's call a spade a spade here. BMR is big on telling us how their parts are tested on fast drag cars. I think that's great that they can make those claims and stand behind them. But we are talking about lowering springs here, not drag parts. Lowering springs are primarily for handling, some use them for looks. And turning is my game. It's what I do, and where my products are developed. You don't see other suspension companies doing what I do, let alone winning National Championships. Though Hotchkis has made a big deal lately about one of their engineers running local autoxes in CA and winning... a far cry from what I do. You can see for yourself over on the Hotchkis site. I've been on the cover of more than one national magazine, and in different cars. I've done magazine cars, and have hard numbers to show the results of the parts.
In fact, the difference my basic suspension makes on an f-body (springs, bars, shocks, UMI PHB) was just shy of the difference in speed of an '09 Z51 vs. a '09 ZR1 Corvette on a road course that was another 3/4 mile longer than what we used for our suspension test. A ZR1 is 4.2 seconds a lap faster (per the newest Car and Driver) @ Grattan Raceway than a Z51 with 200 less HP. The GMHTP car I did was run on the 1.3 mile track @ Englishtown NJ, and was 3.4 seconds faster over that lap... see here for the article: http://www.gmhightechperformance.com...aro/index.html And the suspension had so much more in it that the addition of a set of R-compound type tires dropped another 3.5 seconds. You don't need to believe me, just read the article, and bear in mind the car is driven daily across New York City.
Everyone who sells parts is out to sell their parts. I sell parts too, and believe that the proof of quality and knowledge is in the results, just like BMR does about their drag stuff.
You have a SS, which means you shocks are better than a Z28's stock stuff. Not great to be sure, and if they have miles on them at all you'd be served by a shock change anyway. The fact is that shocks are spring dampers and they should be well matched to get the best result. Can you run lowering springs on stock shocks? Yes, but it's like running a killer head/cam setup with stock manifolds and exhaust. The gains will be muted.
Springs are damped by shocks. Some companies don't sell shocks that are all that great for lowering springs. I sell a lot of brands, Tokico among them. I mention them as other companies offer this shock along with drag shocks only. Tokico's are a inexpensive shock that is so-so when new for lowering springs. I also happen to sell Tokico for a bit less than some of my competitiors. But, I don't recommend them because the quality and warranty aren't what they should be, and the damping while not bad at first suffers greatly with miles. Shocks and springs are a team, they compliment each other when the combination is right. They fight each other when the combination is wrong.
BOSS APPROVED!
