What is the Best Rear Sway Bar for Drag and some street use????
I am going to be having a 438 put in my WS6 and the car will see a lot of track use and some weeken driving in the summer. The car is going to be putting down over 575 to the wheel's and a lot more power with the 200 shot. The car is a M6 too with a 9 inch. So I want to know who has one that is good for both Drag and some street use???
Depending on how much street use you might be fine with the standard 25mm rear bar. If you want to be able to fine tune at the track then you could go with an adjustable Hellwig bar. This would give you something to play with for street vs. strip use. It really depends on if you are planning to drive the car in adverse weather conditions or push the car through the corners. If you are then I would personally stay away from an oversized bar like the 25mm, but it in the end it is up to you. It's times like this that I'm glad I got into auto-x instead of Drag. I don't have to worry about many comprimises . Good luck making a decision.
i can't say a nuff for BMR and the Extreme duty rear sway bar my cars leave so straight and level the auto and the 6 speed car so i got two votes for this product
LS1Tech Premium Sponsor
Thanks for the kind words. Our extreme rear anti roll bar is a solid 1.25" bar that will eliminate any body roll that you might experience. This bar will also make the car more consistant and stable. Although the extreme bar is better suited to the drag strip we do have quite a few customers that use this bar on their steet car as well. If you have any questions about this or any of our products you can give us a call. We are open till 6pm est mon-fri.
