Adjusting a PHR
Old Sep 22, 2003 | 09:51 PM
locosteelersfan's Avatar
Default Adjusting a PHR
I have a Hotchkis unit on the way and
need some tips on the adjustments, install university gives
their usual good write up but its on a non-adj
unit.
THANKS
Old Sep 22, 2003 | 10:15 PM
trackbird's Avatar
Default Re: Adjusting a PHR
Just make sure the axle is "centered" under the car. Find a reference point (A plumbob off of the LCA's or the fender or another fixed point) and make sure the dimentions match on each side (that is why the LCA's work well for measuring, they are in the same place on both sides). Make sure you measure with the weight on the suspension (car on the ground or on jackstands under the axle). Did that make sense? (I thought it did...but I'm not sure).
Old Sep 22, 2003 | 11:36 PM
jd13's Avatar
Made perfect sense. That's exactly the way you want to do it.
Old Sep 23, 2003 | 06:24 AM
mitchntx's Avatar
I took the stock PHB and aligned the new adjustable one with it and made them the exact smae length by inserting the bolts through both mounts.
I snugged the jam nuts and installed the new bar.
I took it down off the jack stands, sprayed a small area of water on my driveway and rolled the car through it, onto the dry portion of my driveway.
I then looked to see if the rear tires and front tires tracked on top of each other.
I measured the difference in track, took 1/2 of it, jacked up the car, adjusted the new bar accordingly and rechecked.
That ensured proper tracking front to rear
Old Sep 23, 2003 | 07:16 AM
trackbird's Avatar
Mitch....I hate it when you make sense.....I never thought of that approach.
Old Sep 23, 2003 | 10:32 PM
SO if the plumbob is one reference point what
is the other end of the measurement?
The tire??
Old Sep 24, 2003 | 11:29 AM
Scalpel's Avatar
Stupid question, but what's a plumbob?
Old Sep 24, 2003 | 11:54 AM
KRAZY K 2000 TA's Avatar
Thats the new Fuit tree they came out with ah new technology
 Michael S. Palmer
Old Sep 24, 2003 | 01:18 PM
Fulton 1's Avatar
http://www.bobvila.com/ArticleLibrar.../PlumbBob.html
Old Sep 24, 2003 | 05:38 PM
DARK AGE 53's Avatar
This is from BMR's web-site, http://www.bmrfabrication.com/instructions/phr002.htm
Al
