Line Lock and ABS
Old Nov 26, 2008 | 12:50 PM
00cls1camaross's Avatar
Default Line Lock and ABS
Does line lock affect ABS at all? I have the hurst one if it makes a difference...
Old Nov 26, 2008 | 07:50 PM
Duffster's Avatar
If you tie it in properly no, it won't affect it in the least
You should go from the reservior front connection to the line lock and then from the line lock to the ABS block front connection. no other valves between. This way, when you press the brakes, the front and rear are unaffected. When you apply the line lock after depressing the brakes, the front's stay locked until you release the line lock.
Done this myself with the hurst solenoid/linelock. Good luck.
Duff
Old Nov 26, 2008 | 08:00 PM
SuperSlow02's Avatar
doubt it...got my abs fuse pulled since im on skinnies and slicks, but I dont see why it would affect it. Nothing but extra line when its not active
Old Nov 26, 2008 | 10:32 PM
SJM Manufacturing Inc's Avatar
No it will not affect ABS functionality. We've got a few styles to choose from listed at http://www.sjmmanufacturing.com/cam_brk_ls1.html
Old Nov 28, 2008 | 03:57 PM
thank you for the replies!
