rear coilovers
when i get the car back from burkhart ill have some for ya but my spring cups have been moved up 2 inches to build a permanet drop into the car without dropping the coilovers and then i have 2 inch drop spindles in the front. i think wolfe has some pics of there stuff on there.
I'd go with the ground control kit. It uses weight jackers instead. These mount the shocks and springs in their stock locations but you can fully adjust the ride hieght of the car. The front is a full coil over shock setup. Here are pics.
https://ls1tech.com/forums/suspensio...rkts-pics.html
thanx for the pics. I just fineshed up the mini tubs and was curious about different coilover setups. i have the spring cups from wolfe already, i guess thats my best option.
