Front driver side inner pad dragging
I'm 99% sure only the inner pad is dragging because the outside of both driver and passenger side front rotors are worn the same but the inside is worn noticeably more on the driver side than the passenger side.
What could be causing this? It can't be the caliper since that was replaced and the slide pins move freely. I pulled on the wheel top-bottom and left-right and there wasn't any play in it that I could tell.
One pad worn way more then the other usually (always) means the caliper is
sticking.
When you use a clamp to push the piston back, pay attention to how much
turning force it takes & compare it to to the other side.
Do both sides close to the same time so you have a frame of reference to
compare. Open the bleeder 1st so old fluid does not back up into the system. If you can`t get the bleeder loose, you will have
to replace the caliper anyway.
Sounds to me like perhaps the caliper is binding. But I'm confused too that the new caliper didn't do it unless it too is bad (as the one replaced). Do you have the ability to return it for another?
I talked to a mechanic friend and he said it is possible the hose is going perhaps, keeping a little pressure at the caliper. And since the pistons are on the back side of the wheel, that bit of unreleased pressure could keep the pistons out enough to make the inside pad rub the rotor but not enough to slide the pins and make the outer pad rub too. I never thought of that, so I'll have to jack the wheel up and see if bleeding the caliper frees up the wheel. If it does, it is a good chance there is a hose issue he said.
