Disabling ABS
I am not going to pull the ABS out of the car, so if you want to recommend that, please don't. When I go to the track I put on MTs which are about 2" larger in diameter than the fronts. I want to know if I can fault the ABS system so I do not lose bias control, but still leave ABS inoperable. Last time I pulled a wheel speed sensor, but it reset every time I restarted the car. Not sure what that does to the bias though, but it stopped well at the track.
