Pagin JimX ..........Where are the WHEEL SPEED SENSORS...?
I need to make sure these are making good contact, before I take the car in for service and get charged for the warranty deductible. My damn ABS INOP light is still on after 4 days. Pics would be life savers..!! Wheres JimX...?
Re: Pagin JimX ..........Where are the WHEEL SPEED SENSORS...?
On the front wheels, they are easy to find.
Remove the front wheel, look at the back side of the spindle and there is a small wire loom with a connector that is plugged into the rear of the hub bearing assembly (the bearing is held on with 4 bolts through the spindle that you see on the rear). That is the easy one.
For 3 channel cars, you should find a single sensor plugged into the center of the rear axle (towards the top I believe).
For 4 channel cars (abs is a 3 channel, abs and traction control is a 4 channel) there is a sensor on each wheel. Look at the ends of the axles.
