Torque Arm Question
Old Dec 18, 2008 | 08:22 AM
Formulals187's Avatar
Default Torque Arm Question
I was wondering if having the correct pinion angle set up on the torque arm would help reduce the chances of brake wheel hop. What should the pinion be set at, i have stock height with 25" tall tires?
Old Dec 20, 2008 | 12:20 AM
shoemike's Avatar
you are having wheel hop under braking?
Old Dec 20, 2008 | 12:46 AM
i have been told that people with tunnel mount torque arms have had problems with brake wheel hop and im going to get mine installed in a week or so
Old Dec 20, 2008 | 01:07 AM
2002 SS's Avatar
i believe it should be set at -2 but i could be wrong...
Old Dec 20, 2008 | 09:36 AM
2000WS6ICK's Avatar
Maybe this will help.
File Type: pdf
Old Dec 20, 2008 | 10:14 AM
OIF1VET's Avatar
I have a tunnel mount spohn, pinion set at -2 degrees.. I have no issues with brake wheel hop..
Old Dec 20, 2008 | 11:55 AM
what size are your back tires that its set for?
Old Dec 20, 2008 | 01:21 PM
the_merv's Avatar
Veteran: Air Force
I don't think the size of the Back Tires are really going to affect how the Axle is sitting..
Old Dec 20, 2008 | 01:26 PM
kyle99ta's Avatar
yeah. your rear tire size shouldn't have any affect. it's all about how the axle sits in conjunction with the rest of the suspension.
Old Dec 20, 2008 | 02:22 PM
so any recommendations for stock ride height? spohn told me about -1 that sound about right?
Old Dec 20, 2008 | 03:50 PM
shaun's Avatar
most guys set it at -2 to start out with.
my car is lowered and the only stock piece back there is the phb which i need to get lol and my tq arm is the aj edelbrock and its set at -1/2 and my car hooks good at the track if i heat up my nittos good and there 275/40/17's.
since your not lowered go with -1 that should work.
Old Dec 20, 2008 | 04:08 PM
omcar's Avatar
I'm at -2.5
Old Dec 20, 2008 | 04:28 PM
stoverz28's Avatar
I don't think being lowered calls for a different pinion angle, sure lowering will change it slightly. The -# is so that underload it will, in theory, be closer to 0 degrees.
Mines at -2 and Im lowered w/ the heater hose mod.
Old Dec 20, 2008 | 05:33 PM
whats the heater hose mod?
Old Dec 21, 2008 | 03:21 AM
the_merv's Avatar
Veteran: Air Force
Taking the Isolaters out of the Rear Springs, and slipping some Heater Hose over the top Coils of the Spring. It lowers the Car about half an inch.
