double drilled?
Old Jan 13, 2009 | 08:25 PM
White94Bird's Avatar
Default double drilled?
has anyone ever heard of double drilled rotors...
What do they look like and are they any better?
Old Jan 13, 2009 | 08:42 PM
Major_Lee_Slow's Avatar
There is absolutely no performance reason what so ever to use drilled rotors. They are for looks only.
Old Jan 13, 2009 | 09:03 PM
Suaveat69's Avatar
Actually GM did a test on drilled vs. non-drilled and the drilled had better cooling and less fade compared to the non drilled. Drilled brake rotors do slow a car down better and it is exponential as speed increases. Drilled rotors have less fade. So, yes they do provide a benefit BUT they will CRACK under extreme use.
http://www.sae.org/servlets/productD...D=2006-01-0691
