replacing brakes
Old Oct 3, 2003 | 08:55 PM
LSUZ28's Avatar
Default replacing brakes
I'm about to redo the brakes all the way around on my car. The guy at Oreilly's told me that I needed a special tool to compress the rear calipers. It that true? I though you could just use a clamp and compress them like the front ones.
Thanks
Tim
Oh yea, car is an 02 Z28
Old Oct 5, 2003 | 04:32 PM
LSUZ28's Avatar
Default Re: replacing brakes
2 days, no help?????
oh well, I got my answer else where
Old Oct 5, 2003 | 05:59 PM
FinalTA's Avatar
You CAN just use a clamp. Get a 6" C-clamp and go to work...
-Jason
Old Oct 5, 2003 | 08:55 PM
mcflyz28's Avatar
I use big channel locks the rears are easier than the fronts the fronts have two pistons.
Old Oct 5, 2003 | 09:38 PM
wrencher's Avatar
wrencher
If you want to remove the rear rotors the p/b self adjusters might have to be backed off to get p/b shoes off the inside of the hat/drum of the rotor.
The weekend is always alittle slow to get a quick reply.
Maybe also title your post as "how to compress rear calipers" instead of just "replacing brakes". I bet it wont take 2 days then, just a suggestion.
