Removing Calipers
Old Oct 4, 2003 | 11:10 AM
1998CruzMssl's Avatar
Default Removing Calipers
I want to remove my calipers to paint them and was wondering if I have to bleed the system if I do this? If I do how hard is it and do I need any special tools or equipment...thanks in advance.
Old Oct 7, 2003 | 07:58 AM
onehardmaro's Avatar
Default Re: Removing Calipers
Yes you will have to bleed the brakes. Just removing the calipers isnt going to bring to much air in the system, so it should on take 3 to 5 minutes per caliper. All you need is a buddy to press brake pedal and i think a 10mm. Start with the right rear to left rear to right front then left front. Also keep and eye on the resevior(sp), dont let it get to low.
Old Oct 9, 2003 | 04:39 PM
weasel_ss's Avatar
If you are going to remove the calipers, be really careful not to get any brake fluid on your new paint. Brake fluid can screw up your fresh paint pretty easily.
