I'm a happy man.
I'm a happy man.
The BMR adj phr came out and the G2 double adj phr went in. No more tire rubbing! I haven't tested it under extreme conditions, but it's a very close call. Half a turn of the phr to either side will result in very minimal rubbing. I'm happy for now though.
Now I just gotta figure out what's loose on the front end that's resulting in these clunks I'm hearing...
Re: I'm a happy man.
Ok, did some more testing last night and the rubbing is there slightly on one side. I should be able to fix it with the phr.
The clunks are just from my shocks being loose (hopefully). The front suspension has new springs, shocks, and a swaybar.
Hey.. if you are still clunking in front, there is a bushing under the top of your front shocks that might be missing or damaged. Check those,.
I had to beat the inner fenders and do some adjustments with the PHB and right now i have it where it is very close and only rubs on really big *** bumps.
