How to pull axles? and e-brake question
1) Remove wheels, calipers, and rotors
2) Remove rear end cover
3) Remove pin/block in the middle of the differential, one bolt hold it in place
4) Unbolt TCS sensors on the backing plates
5) Push axles in and remove C-clips
6) Pull axles out
7) Put everything back together in reverse order
Not sure about the e-brake thing. You can pull the shoes, and probably the expander thing, but I'm not sure if it is part of the backing plate.
