Adjusting LCAs and PHB
Old Jan 20, 2009 | 12:53 AM
Kingc8r's Avatar
Default Adjusting LCAs and PHB
I've tried a search. Maybe I'm not putting the right keywords in.
I just lowered my car with Strano Springs. I have UMI relocation brackets, ADJ PHB & LCAs.
It was brought to my attention that my rear tire is too far back. How do I fix this. Any links or insight would be appreciated.
Old Jan 20, 2009 | 12:54 AM
evilbeef54's Avatar
did you get the adjustable lca's or the non adjustable
Old Jan 20, 2009 | 12:57 AM
Kingc8r's Avatar
I have adjustable everything
Old Jan 20, 2009 | 01:50 AM
99Bluz28's Avatar
Lightbulb
First make sure you have the LCAs in the relocation mount holes that you plan to keep them in. Then at ride height measure how far off center the wheels are, divide that number by 2, your answer will tell you how much you need to shorten the length of the LCAs. Back the car up on ramps(leave the car in gear, and set the parking brake) and block the front tires. If there's enough inward adjustability on one end of the control arm, then just drop one end (the axle end will be the easiest) adjust it, remount it, then do the other side.
Old Jan 20, 2009 | 12:44 PM
Big Bird WS6's Avatar
^ ^ ^ that is what i hate about umi ones. hard to adjust. i like DKT ones cuase i lossen both jam nuts and twist.
Old Jan 20, 2009 | 01:06 PM
UMI Performance's Avatar
It depends what model you get... the single adjustable's must be removed to adjust. The double adjustable's allow you to loosen two jam nuts and turn the control arm on the car to lengthen or shorten the arm. Our on-car adjustables are the same way which feature poly bushings on both ends.
Old Jan 20, 2009 | 01:32 PM
Kingc8r's Avatar
I wish I would have known this before I ordered my Poly/Rod Adjustables. Oh well, so I need to measure then take one side of the LCAs off and adjust it accordingly?
Old Jan 20, 2009 | 01:58 PM
bobbyd's Avatar
so the double adjustable ones are the best ones?
Old Jan 20, 2009 | 02:09 PM
BMR Tech2's Avatar
LS1Tech Premium Sponsor
Thats the best way to do it. Just make sure that you get both sides the same length.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old Jan 20, 2009 | 02:52 PM
yes. makes it alot easier to adj.
Old Jan 20, 2009 | 03:45 PM
koolaid_kid's Avatar
That is a leading question. They are the easiest to adjust. The question you have to ask yourself is: How often am I going to adjust them?
Then base your decision (in part) on that answer.
Old Jan 20, 2009 | 04:27 PM
barnat's Avatar
Default UMI LCA,s
Ive got a brand new set of the UMI double adjustable LCA in red that I bought last month that i never used ! If somebodys in need!
Old Jan 20, 2009 | 10:38 PM
pwterz28's Avatar
so if i lower my car i need adj lca to
Old Jan 20, 2009 | 11:21 PM
wht01ws6ta's Avatar
The adjustable LCA are to center the rearend forward/rear in the wheel well. If you're lowered you need LCA relocation brackets to correct the suspension geometry to what it should be (and I have a set of used UMIs for sale coincidentally)
Old Jan 21, 2009 | 07:44 AM
sorry ryan, i dint know umi made ones like that. but if umi does. then those are great too. i know bmr makes a a race rod style. so does bmr. but i am pretty sure will a poly mount on both ends and full adjustable. pretty sure 6litereater is the only one that has thsoe right now.( and i might be wrong, but pretty sure not)
Old Jan 21, 2009 | 09:07 AM
Like mentioned you will not need adj. lower control arms if you lower the vehicle. We do however recommend a adjustable panhard bar. When you lower the vehicle the rear end will shift slightly and the panhard bar is used to re-center it.
Hope that helps!
Ryan
Old Jan 21, 2009 | 09:45 AM
bobbyd's Avatar
Hope that helps!
Ryan
whatb aout if the car is lowered and going to put some 315s in the back? will i need adj lca's then?
Old Jan 21, 2009 | 09:51 AM
You will be just fine with out adjustable lower control arms. I do highly recommend a adjustable panhard bar... being lowered and 315's in the rear will most likely lead to some tire rubbing.
Now if you have a aftermarket rear end like a Moser you will want to the adjustable control arms, but factory and Strange are ok.
Hope that helps!
Ryan
Old Jan 21, 2009 | 11:10 AM
bobbyd's Avatar
Hope that helps!
Ryan
thanks. yea i got a adj phb on the sale you guys had for black friday
Old Jan 21, 2009 | 11:36 AM
xBROKEx's Avatar
how do you decide what holes to use on the relocation brackets?
By Brett Foote | 2026-06-04 05:00:17
