Problems installing Spohn ds loop
Old Jan 20, 2009 | 12:05 PM
cmking26's Avatar
Default Problems installing Spohn ds loop
I can't get the top arched piece that goes over the driveshaft on. The instructions say to put it on from the drivers side up at the front yoke. No luck there. Its too tight to fit. Anyone else have problems?
Old Jan 20, 2009 | 12:56 PM
99Bluz28's Avatar
Jack the back of the car up and put it on jackstands, you want the rear suspension at full droop. Now put it over the drive shaft back by the rearend then move it up front.
Old Jan 20, 2009 | 12:58 PM
cmking26's Avatar
Ok Ill try that maybe tomorrow. When I was doing it today I had the front lifted up.
Old Jan 21, 2009 | 06:13 PM
Magic Man's Avatar
You could pull the drive shaft then put it in.
Old Jan 21, 2009 | 08:30 PM
toothdoc's Avatar
I was thinking the same thing.
Old Jan 21, 2009 | 09:14 PM
cmking26's Avatar
Dont wanna drop the driveshaft. Im lazy
Old Feb 20, 2009 | 01:15 PM
cmking26's Avatar
Well I tried lifting the weight of the car while rear axle was on stands. Still can't get the loop over because the torque arm is in the way. It just pisses me off that I now have to drop the driveshaft when the instructions say "No Need to Remove Driveshaft". Ok Im done ranting now.
