Front Shocks only
that said, the stock shocks don't have the damping to properly control the stock springs, much less lowering springs. will it work? yes. will it work well? probably not.
it won't really "hurt" anything physically to use the stock shocks on rear lowering springs, per se, but i think if you do lower it on the stockers, it will light a fire under your *** to replace them with some Koni's in the rear as well.
but they should work long enough for you to save the money for the Koni's, assuming they're not already thrashed.
You might be able to swing a pair of (Strano spec) Bilsteins for the rear, or even cheaper, Tokicos ... and either one would be a big improvement over the old stockers.
anyway, like i said, you can use the stock rear shocks for a while until you can afford some adjustables, but with the rear being lowered (usually 5/8" - 3/4" when doing the hose mod), the stock shocks are going to wear out quicker.
