1" lowering springs
(1)
Koni SAs with factory springs on the lower spring seat perch up front for around 3/4" lowering, then do the "hose mod" in the rear for around 1/2"-3/4" lowering.
(2)
Or you can get some SLP level 2 lowering springs for around 1/2" lowering, Frt. & Rr..
(3)
GroundControl front adj. ride height kit, for the rear the "hose mod."
(4)
GlobalWest front adj. ride height kit (the best kit), and for the rear the :hose mod".
(2)
(3)
(4)
Moderator
My Hotchkiss were spot-on advertised -1" drop at
all 4 corners. But an dead-even drop makes for a
dragging-*** appearance. I gave my rears to a local
guy with Eibachs (same problem only lower) and the
Hotchkiss rears gave him a better rake.
The SLP Eibachs that were a "factory" option were
about -3/4".
about -3/4".
for looks and quality I would go with strano's... they are a little less than 1" but I think they look better than the hotchkis which are rated at 1"... I think strano's are rated at 1.2"
I did the lower mount on my Koni SA's and the hose mod on the rear with stock springs and mine is higher in the front for sure. I guess I'll have to put the isolator back in or go with Hotchkis. My issue is I drag my driver side cat if it's too low like my LT1 Eibachs were.
