Need help with cars handling
I have a 94 Trans Am, I have rebuilt the entire front end, new bushings, upper/lower ball joints, inner/outer tie rods, you name it. I do not get uneven tire wear. My problem is that my car follows ever line in the road. I know I have 275/40-17's in the front, but really this is excessive in my opinion, and I feel it is wearing out my new parts. Stock ride height and stock alignment specs. Car will drive fine on smooth roads, no pulls or drifting. So what can I do to reduce this . And yes alot of the roads suck around where I live, they half *** repair them and put wavy lines in them with tar and small gravel that gets embedded into the road surface. Looking for suggestions.
tia
andy schuck
tia
andy schuck
tia
andy schuck
tia
andy schuck
Running slight toe in about 1/8" on each tire all but eliminated my trammeling(sp) and shows no exxagerated wear. Hell it may have been 1/16 toe each tire it's been a year and a half but it should be in the glove box
If your tire are already worn abnormally from the front being previously out of alignment that can do it too.
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
