Best Sub Frame Connectors
Old Oct 9, 2003 | 08:40 AM
mikez28's Avatar
Default Best Sub Frame Connectors
Can anyone give any comments on their opinions on subframe connectors? Are they worth it? Which brands are good/bad? Welded or bolt on? If the board could give me any comments that would really help me in choosing the right type/brand. Thanks in advnance!
Old Oct 9, 2003 | 09:08 AM
trackbird's Avatar
Default Re: Best Sub Frame Connectors
Any are better than none at all.
I prefer a "3 point" design, like SLP.
Welded or bolt on?
If it is an option, I always weld them.
I like my SLP SFC's. Many like the Kenny Brown SFC's (I'm not a big fan, but they are still better than many others available). If you can't/wont do a 3 point design. Look at the LG motorsports kit (you can add the cross braces later on, they bolt in). Actually, you may want to look at the LG kit anyway. It looks to be very well designed and with the cross braces and driveshaft loop, it should be a great way to go.
My thoughts.
Old Oct 9, 2003 | 04:20 PM
ssfiress's Avatar
i love my global west weld in. one of the first mods and a good one. got ridof the body flex over speed bumps and just pulled my car together better
Old Oct 9, 2003 | 07:44 PM
wrencher's Avatar
wrencher
IMHO every F-body should have these installed.
my $.02......
Old Oct 9, 2003 | 08:20 PM
WicketMike's Avatar
I have BMR's welded and there great. i can tell a big difference vs. driving my other Trans Am w/o them.
Old Oct 10, 2003 | 12:12 AM
Ferocity02's Avatar
My thoughts....
https://ls1tech.com/threads/showflat...31&fpart=1
Old Oct 10, 2003 | 08:53 AM
WILWAXU's Avatar
The Kenny Browns tighten the car up very well. They're a little heavier, but well worth it IMO.
Old Oct 10, 2003 | 03:33 PM
Stone0fFire's Avatar
man i went to speed inc,
and just take a look at the KBDDs
how can you settle for anything else?
the SLPs come close, though
then again,
who's to say you can tell just by looking?
my hijack Q is,
if you get KBDD's,
will that interfere with other possible mods?
like, driveshaft safety loop?
or 3" true duals?
or anything else?
Old Oct 10, 2003 | 08:22 PM
WILWAXU's Avatar
Kenny Brown most everything I know of.
There is one type of long tube header the needs one of the foward tubes tweeked to install them, can't remember which ones. FLP's maybe?
Old Oct 12, 2003 | 03:13 PM
miner_49's Avatar
Some subframe connectors have more of a ground clearance problem than others on lowered cars as they stick down below the frame (such as the SLPs). Others like the Hotchkis design tuck up nicely out of the way.
Old Oct 12, 2003 | 10:45 PM
6Gearss's Avatar
Your choice and what you're doing with the car. I don't do anything extreme so I went with BMR, tightened her right up along with a STB. Can't be seen from the side, you have to crawl underneath to see them pretty much.
Old Oct 13, 2003 | 12:27 PM
TWS's Avatar
TWS
I have the Hotchkis on my '94. And totally back up what he's saying. They are weld-ins and tuck up very nicely. Makes a noticeable difference in handling/structural support, but are hard to see. Just notice a little "hint" of red when looking at the car from the side 20' or more away.
They are "2-point" weld-ins, so not as effective as the KBDD or other similar brands, but made a big enough difference for my purposes. We bolted them in the back through the LCA holes, then welded around those brackets for the LCAs. Then welded the "flats" on the ends and tacked along the sides on the thin lip running under the doors. Fair amount of welding. Bottom line they are ON there!
Old Dec 22, 2004 | 11:00 AM
audiopro's Avatar
You say the Hotchkis are 2 point weld-ins. Are the BMR's 4 point? In looking at some install pics of BMR's it looks like the mounting plates extend to multiple portions of the front frames and are welded. Are the Hotchkis not the same? Looking at the design of the Hotchkis it looks like they may only mount to one portion of the front frame..
Thanks...
Old Dec 22, 2004 | 11:36 AM
Flaminchiten67's Avatar
My thoughts exactly. Just ordered a set from AP-Engineering best price I've seen on SFC. I would suggest jumping on one of the many deals going on right now on suspension components.
Old Dec 23, 2004 | 12:15 AM
Flawless02SS's Avatar
The Kenny Brown DDs are the only way to go. Super design, I will have to say that it is the best MOD on my car so far. And go with the weld ons, u wont have to worry about bolts backing out.
Old Jan 1, 2005 | 04:28 PM
OldeSkool's Avatar
I have the BMR boxed variety sfc's welded in. Makes the car feel real solid. Tubular suspension pieces, poly bushings and subframe connectors makes it feel like my old C4 vette... almost.
Old Jan 1, 2005 | 09:57 PM
Croaker's Avatar
Couldn't agree more, I ordered a set of BMR tubular SFCs from APE yesterday myself.
Old Jan 4, 2005 | 06:18 PM
Tonyss1's Avatar
Thumbs up Best subframe connectors
Wolf racecraft has the ultimate subs ,there the through floor design. There by far structurally the absolute best when you combine them with there cage and torque arm. I had the kenny brown double diamonds for years, and are easy to install, I'd say if you allready have a cage go with the BMR's or kenny browns. If your car does not have a cage yet and your planning to build a serious race setup the Wolf subs are alot more work but there the best. T
Old Jan 4, 2005 | 06:55 PM
Carlos01SS's Avatar
LGMotorsports, very beefy.
Old Jan 24, 2005 | 02:44 PM
OWENMUSTANG's Avatar
KBDD. i have no idea where the header interference rumor started
but, lay under a kbdd car. the only way a header could interfere with the sub is if ends up dead smack under dr/pass feet!
