Torque Arm adjuster stuck
1 Post
I have a BMR adjustable torque arm that i'm trying to use to adjust my pinion angle. Both the lock nuts came loose no problem, but the actual adjuster wont move. i've yanked on that thing with all my might, and tried moving it in both directions to no avail.
before i give myself a hernia, it it typical for these to get stuck, and is there any advice to getting it to move besides removing the TA from the car? like can i put a jack on the rear end to take pressure off the adjuster or something?
after I installed a poly tranny mount, i decided to check my pinion angle. measuring from the drivers side, i got 84* on the rear end and 85* on the driveshaft... thats -1, right? i wanna try -2.
1 Post
Ryan, it's been on the car for 3 years. i've actually never even adjusted it at all, because it lined up to an acceptable pinion angle at initial installation.
i'll hit it with some PB blaster and see if that does the trick.
