Sub frames
Old Feb 12, 2009 | 07:44 AM
GatorFan08's Avatar
Default Sub frames
Could I go to the track and run slicks without sub frames?? It would only be for a few times.. But I dont have my sub frames yet and I dont want my car to start ripping. Would it be ok??
Old Feb 12, 2009 | 07:53 AM
Fotis's Avatar
it will fall apart first time down don't do it lol jk
Old Feb 12, 2009 | 08:10 AM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
You'll be fine, it would take a lot more than that to rip the car apart.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old Feb 12, 2009 | 11:27 AM
Fotis's Avatar
lol
Old Feb 12, 2009 | 01:01 PM
z28bryan's Avatar
If your referring to Nittos, those things aren't grippy enough to be even close to worrying about that.
Old Feb 25, 2009 | 09:48 PM
GatorFan08's Avatar
lol, well my budd in mustang has been running his car w/o sub frames now his torque box is messed up. i dont want the same thing to happen to me
Old Feb 25, 2009 | 10:03 PM
Elliott's94Z's Avatar
You will be just fine
Old Feb 26, 2009 | 07:20 AM
UMI Sales's Avatar
Thumbs up Hello
Hello
The mustangs have that problem when people overlook the essentials. I am actually surprised it didn't mess up the door pins too... You will be fine just don't forget when you can get a set!
Take it easy!
Brad
Old Feb 26, 2009 | 10:40 AM
Fotis's Avatar
its a the problem with his car ia that its a ford and second of all its a mustang
don't worry you got better quality also get some M/T not nitto, those things don't got very good grip
Old Feb 26, 2009 | 11:20 AM
meine96ws6's Avatar
Just get the subframe connectors..
Old Feb 26, 2009 | 01:45 PM
dlandsvZ28's Avatar
Tip: Make sure that when you do install the subframes that the shop welds them in on a lift where the suspension is loaded (a drive on lift). They should disconnect the battery too.
Old Feb 26, 2009 | 09:31 PM
Fotis's Avatar
i agree, the bolt on Sub frame connectors aren't as good but you can get the ones that are bolted then welded
Old Feb 27, 2009 | 12:08 AM
4WOFURY's Avatar
Just for clarification, why is this?
Also, my car was ran pretty hard I'm assuming before I got it. I know it saw quite a few track passes, without SFCs. This is the result:
And quite a few other cracks from flexing all around the hatch area. Also about 5-8 dimples on the rear quarter per side.
I would get the SFCs before running it hard.
Old Feb 27, 2009 | 07:42 AM
barnat's Avatar
Default Umi
There's guys on here ALL THE TIME demodding and selling theres!!!I got UMI's 3 points myself !!but any good brand name will work.The UMI's tie into the tunnel brace and more or less ties the whole car together ,thats why i like em and you loss as much ground clearance as the rest of em IMO
Old Feb 27, 2009 | 07:50 AM
UMI Sales's Avatar
Thumbs up Thanks
Hello,
Thanks for the shout out! And glad that you like the product! Our 3-point sub frame connectors are designed for maximum strength and pure performance. If you have any questions feel free to ask and I will be glad to help.
Thanks Again
Brad
Old Feb 27, 2009 | 09:54 AM
BMR Tech's Avatar
The cracks you are experiencing are not from lack of subframes.
Think of it this way look at where the subframe adds addition chassis support and look at where the cracks are.
The only loading that portion of the car receives is from the springs and shocks being exercised during a launch or handling maneuvers and subframes are not going to aid in that area.
