UMI K-member install help
I bought a road race k-member from UMI, i am still installing it, Cant seem to line up all six bolt holes for the k-member to frame. What is the easiest way to get them all to line up? Right now, all 3 on the passenger side line up and the very back one and the middle one on the drivers side line up.
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
Hello,
I have a few questions for you. First does the Dial pins in the frame line up? And when you installing the K member did you leave the motor mounts loose to eliminate a binding problem? We have experienced getting all bolts lined up and started and then tighten down. If you have any other problems or questions feel free to call in and we will be more than glad to help you!
Thanks Again,
Brad
Thanks Again,
Brad
Hello,
Thanks Again,
Brad
Thanks Again,
Brad
those threaded inserts you're bolting the k-member into will move back and forth a bit. You can see them sticking out the sides of the framerails, they're usually fairly easy to move. If only one isn't lining up that insert may have just moved a bit off what you need.
Hello,
Its probably easier for you to give us a call and we will be able to better assist you. I talked to our tech support about this and they will be more than glad to help.
Thanks again
Brad
Thanks again
Brad
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Although I havent got it done yet.
![Embarassed](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_emb.gif)
So I finished the install, with the upper and lower a-arms, went to road test it. Alignment being way off was expected. But when I steer it makes a clunking noise and some other noises too. And the Steering also feels weird.
Hello,
It could be a lot of different things. Sounds like you don't have something tightened! Might want to double check all the hardware and make sure everything is tight. Hope that could Help. If you have any other problems leave us know and we will be glad to help.
Thanks
Brad
Thanks
Brad
It was probally the sway bar endlinks cause they were at an extreme angle.and they werent lining up right when I installed them. But I did tighten everything down to factory specs.
Like we mentioned before have a alignment shop look at and and get the car set up for you and see how it rides then! If you have any other problems feel free to contact me and I will be more than glad to help.
Thanks Again
Brad
