Where to weld bolt-on SFC's?
Alright, I bought a set of 3 point bolt-on SFC's from a guy that fabricates them on another board. The bolt holes did not quite line up, so I had to slot/open the holes (not the one that goes through the LCA)on a milling machine. Now I'm afraid that they will move around, so where and what are they welded to? Any one got pics? Any help would be appreciated. Thanks.
Re: Where to weld bolt-on SFC's?
Normally, you would weld the plate that the bolts run through on both ends and you may (depending on design) be able to weld them to the pinchweld under the door that runs along the bottom of the car.
Who manufactured these? Just wondering....
Was the guy's name Don Goetz???
I also forgot to ask if I need to disconnect the battery when having them welded on. I wasn't sure if it would screw up the computer. Thanks.
