update on umi torque arm destroyed
Old Feb 24, 2009 | 09:22 PM
to-fst-4u's Avatar
Originally Posted by SKI
If they supply 4 bushings with there TQ arm or sale them without the arm for 12bolt rearend's all this blaming everybody would be over......
agreed.
Old Feb 24, 2009 | 11:26 PM
tillery's Avatar
I sent EPP a bushing to think about for the Moser rear,Havent heard any feedback. Would gladly send to any sponser to mull over. Thing is that it needs to be made to make up the diff in sizing and thickness to the Tq Arm being used. Stress that proper Tq is required. a thick washer is needed. and at least one-three threads need to protrude into the Moser mount. Locktight is an easy solution. But only works if properly used. Safety wire is the best. But if you dont know how to do it. It wont work. Aircraft mechs know about high frequs. And know that it will lead to metal fatuige. These Tq Arms should not be failing no matter who makes them. As long as they are installed correctly with proper hardware,
