twin caliper rear brakes
Any of you guys running rear twin calipers. Sense the new convertor, i was considering going to this set up to help bring the car up on the foot brake. If you run wilwood rears singles or doubles how do perform against the stock ones. thanks Phil
i havent looked at wilwood's stuff in a while but most twin caliper setups are only for track use. they're not supposed to be used on the street because the rotors are much thinner than normal street rotors and very likely to warp under normal driving conditions. secondly, twin calipers would be even more likely to warp given that they're receiveing twice as much heat infput.
i'm not saying that it's impossbile, but you're probably better off going with a really good set of pads, brembo rotors and Stainless brake lines. you may also want to consider (i'm throwing this idea around too) a new master cylinder, aparently the difference is night and day compared to an old leaky master cylinder like most of these 10-year-old tubs have by now.
gm...there was a recent thread about this somewhere, if not here then in the general maintainence section.
the diaphram and seals in the master can leak and bleed off break pressure, the older the car gets the worse the leaks are the more pronounced the pressure loss is. because its such agradual process its one of those things that you never really notice until you replace the thing tho.
