Brakes question.
Old Oct 13, 2003 | 06:49 PM
kmdracer's Avatar
Default Brakes question.
Just changed the front rotors and pads, and rear pads on the 99 Z28. Is the prcedure for bleeding brakes the same as always (start at right rear, etc), or is there something different to do with 4 wheel anti-lock brakes? I haven't done it yet, was worried about messing up. Now the car is VERY squirly under heavy braking. ( Pulls to left, then right so on ) I bought the Autozone rotors this time. Hope they last longer than the stock P.O.S. ones.
Thanks for help, Kevin D.
Old Oct 15, 2003 | 04:49 AM
Guardsman's Avatar
Default Re: Brakes question.
Same procedure with ABS. Did you bed the pads before you started slamming on them? If not, that could be why they're acting squirrely.
