Which line lock?
Old Oct 14, 2003 | 07:30 AM
Dragaholic's Avatar
9 Second Club NA
Default Which line lock?
Im looking into getting a line lock and I was wondering who made the best one or whats more preferred around here. Im not sure what would make one better than the other, but which one will have everything that I will need for it, is user-friendly, easy to install, has least problems, is highly recommended, etc. etc.? Any help is much appreciated. Thanks
Old Oct 14, 2003 | 08:18 AM
MINEZQKR's Avatar
Default Re: Which line lock?
SLP has worked fine for me so far
Old Oct 14, 2003 | 06:22 PM
Dragaholic's Avatar
9 Second Club NA
Any other suggestions? I want to keep my options open, but if the SLP unit is what is highly recommended/used, then I guess I will go with one. Does the SLP unit fit what Im looking for in one? Thanks
Old Oct 15, 2003 | 09:08 AM
BigBake's Avatar
SLP all the way on this. It comes with pre-bent lines and fittings. The wiring harness is already set-up for installation and correct length. Comes with easy instructions, and shouldn't take you more than an hour to install. Just have an idea where you are going to put the switch.
Old Oct 15, 2003 | 11:28 AM
Dragaholic's Avatar
9 Second Club NA
This SLP kit...is there just one, or do they offer different ones? Just dont want to have to go through the trouble of looking, deciding, and then having to post more questions. So far we have 2 votes for the SLP unit, who else is running one? Thanks ya'll for your help. I really appreciate it!
Old Oct 15, 2003 | 12:11 PM
BIGBOS's Avatar
I vote for SLP too, all the stuff comes pre bent, and its probably the best bang for the buck, I beleive hurst makes one too, but its like 40 dollars more...
Old Oct 15, 2003 | 01:28 PM
2KThunder's Avatar
SLP. The install is painless. It works great, and for its price (which it has all the fittings and switch) is a great choice. You could get a more expensive one, but your not going to get the prebent brake lines, switch, etc..
