What is everyone running???
8 second mod
I have front hals, and im doing rears on monday, What settings are the most of you running? Ive talked to a few people, they say with my set up and tires (27x11.5x15 Hoosier QTP) I should be around 4 up front 3 out back, Any imput where to start would be great.
I run no sway bar, have the fronts on 3 now, and airbag @ 7psi, and cut 1.55-1.60 60'
Thanks alot
Thanks alot
![The Patriot !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_patriot.gif)
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I got hals in the front and rear, and I'm running a Hoosier 27x11.5x15 tire....I have V8 springs in the back with no airbag..
Last year on motor I had them at 4 and 5 in the back, 5 on the right to keep it tighter for the launch, and I tried 0,1,2 in the front, they all worked basically the same, zero was actually better...
This year since I'm running the iron block in the front and have a different spring setup in the back...I will try 5 and 6 in the back, and 3 or 4 in the front to start with, leaving on the trans brake with boost is going to be interesting...
8 second mod
Cool, Sounds good. I think I'll start with the Air bag empty, find the best 60', then play with the air bag and see if it helps. If not, they come out and i loose a few pounds!!
