panhard adjustment issue OR ?
Old Mar 13, 2009 | 09:33 AM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
Originally Posted by UMI Performance
I just don't agree with this, maybe you do and each to there own... but this won't get us anywhere other then making a mess of the original posters thread....
Not make a mess, he was content with the information and said he got his question answered. This is just a friendly discussion on the topic. But like you said to each their own, neither of us are going to sway each other either way. Maybe people can read our discussion and make up their own minds.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old Mar 13, 2009 | 09:34 AM
UMI Performance's Avatar
Agreed
Old Mar 13, 2009 | 02:04 PM
98nosz28's Avatar
I am about to do this also. I have adj LCA and panhard. My car is so low it is a pain to jack up and down. I am going to drive the front onto ramps. Jack the rear up just a little lower than level. Put jack stands under the rear frame. Adjust as needed. Then jack up on the diff to get the weight onto the chassis and measure. Repeat as needed. Would this not work the best?
Old Mar 13, 2009 | 02:30 PM
Shoulder Shaker's Avatar
Same thought here. I will be listening.
Old Mar 13, 2009 | 03:35 PM
BMR Tech2's Avatar
I would suggest driving the front onto the ramps and putting the jack stands under the axle instead of the frame. Do one side of the control arms at a time. Make them the same length as the ones that you are taking off. Your car will have the suspension loaded so do the adjustment on the panhard. Take your measurements, adjust as needed. Tighten the jamb nuts and your done. If you have any questions give me a call.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old Mar 13, 2009 | 03:42 PM
98nosz28's Avatar
Ya but according to UMI that is still loaded and with his thoery it would push the car off the jack stands.
Old Mar 13, 2009 | 04:33 PM
BMR Tech2's Avatar
The only way that would be possible is if the body was held stationary. You can take the panhard bar off of the car and move the body side to side in either direction without the car coming off of the jackstands. We just had one of our employees car up on the drive on lift and we took the panhard off of the car. Put an adjustable one and adjusted the bar. The car had full weight on the suspension and it did not scoot the tires or try to come off of the lift. We got the body centered, tightened the jamb nuts and thats was it. No raising or lowereing of anything and only had to do it once.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Old Mar 13, 2009 | 05:20 PM
Danny2tek's Avatar
Greatest thread ever!
Old Mar 13, 2009 | 06:15 PM
leadfoot4's Avatar
You could say that....on the other hand, you could say that it shows how many people are really in need of some training on how an automobile works.
Old Mar 14, 2009 | 06:31 AM
Hello, Its no so much a theory but things we have learned from past experience. In this case I would place the jack stands under the frame and let the rear end hang freely again and make my adjustments that way. You can then place the jack under the rear end and jack the rear end up to simulate the suspension is loaded and see where the rear end is. Either may with the control arms may work but this is just how we would do it.
Hope that helps,
Ryan
Old Mar 14, 2009 | 10:33 AM
98nosz28's Avatar
Hope that helps,
Ryan
Ya I think that is the best way also. It is the easiest for us guys doing it without a lift. That is why i said I would put the car onto jack stand a little lower than level. Then when i jack it on the diff to simulate loaded suspension the car would be level. Should make it nice and easy to let it down again to do adjustments.
Sometimes it takes arguments like this to get more people opinions on how they have done it or think it should be done. But long and short is mine is UMI parts so I guess I will listen to Ryan
Old Mar 17, 2009 | 11:04 PM
  #32
Scammper's Avatar
UMI and BMR... thanks! Like our teachers always told us "There is always more than one way to solve a problem."
I already have the body on jack stands for my exhaust project. So I will be attempting the method of raising the axle until the suspension holds the full weight. Measure... then drop the axle to adjust. (My two cents: adjusting the par loaded shouldnt hurt anything... but adjusting the bar should be much easier when its only moving a free hanging axle.)
I still have a question on the "measure" step. I know this step should be easy, but I was curious what landmarks you guys use to measure... (btw, I have the wheels off...)
I feel like Im just swagging it with a tape measure. Is there a good trick to getting it dialed in?
Old Mar 17, 2009 | 11:46 PM
  #33
Magnet's Avatar
I have never seen two good sponsors like UMI and BMR disagree on a point like this before..
Old Mar 17, 2009 | 11:53 PM
  #34
Kingc8r's Avatar
That's amazing considering you have been around since 2004.
Old Mar 17, 2009 | 11:55 PM
  #35
Magnet's Avatar
Normally the good sponsors like they are agree on all the major points.. They may disagree on who's product is better or what not (which they never discuss), but never on something like this..
Old Mar 17, 2009 | 11:57 PM
  #36
Greekey's Avatar
I dont see how a panhard can be adjusted with the wheels on the ground..I just thought all the stress was suppose to be off of these parts before adjusting them, meaning, the tires off the ground.
Old Mar 18, 2009 | 12:00 AM
  #37
Kingc8r's Avatar
Good point.
Old Mar 18, 2009 | 04:30 PM
  #38
BMR Tech's Avatar
I would go from the center of the wheel well to the mounting face of the wheel....
Old Mar 18, 2009 | 04:45 PM
  #39
Bad Blue WS6's Avatar
This is a great thread!!! lots of good stuff from both BMR and UMI (i have both on my TA) Glad to see its civil,,,,,, now hire some female oil wrestlers, equip em with company logoed bikini's, and settle this thing the way we all want,,,,,greaseiest woman left standing in the oil filled kiddie pool wins!!
Old Mar 18, 2009 | 05:38 PM
  #40
leadfoot4's Avatar
How would you measure whether or not the axle was centered, if the car DIDN'T have the suspension loaded, and was at "ride height"??
I can understand not being able to reach the adjustment sleeve of the bar if the car was "on the ground", so a drive on lift or alignment rack would be ideal. However a set of ramps will suffice.
