Eibach Pro Kit Vs Sportline Kit
Looking for people with either kit, I'm looking to lower my 94 Z28 but am looking for an advantage in drag racing and also overall appearance.
Got a pic of your ride on Pro's or Sportline's? Post Um Up and your opinions.
Sportlines handle great compared to what? I can't imagine an fbody handling good while riding the bumpstops...
I had a prokit on mine and had them taken off .. its bad when you rub your y-pipe all over town and have to avoid certain streets and stuff. Its now back to stock height and have true duels (another reason for the change) I should have just saved for adjust. struts and could set it any way I liked it or change it when needed.
I bought a set of sportlines before I had a chance to read up on how terribly they're received on this board. Had I read that, I never would have bought them since I definitely trust this board on things like that. But what the hell, I bought them (as well as a set of KYB AGX's) so I figured I'd at least throw them on and see what happened.
As soon as I finished installing them and was about to take it for a spin around the block, I completely expected to be bottoming out everywhere and that I'd be bouncing around like a car on cut springs. This was not the case AT ALL. Yes, it rides rougher than stock, but I'd expect that with any lowered car. Overall, I barely notice a difference between my current setup vs my stock setup on 90% of the roads around here. (I wondered if maybe my stock shock/spring setup was worn/bad, but the stock shocks werent leaking and everything looked fine) I figured I'd be feeling every tiny bump and crack in the road since that's what everyone said would happen--but I don't. I definitely don't think they're as bad as most people make them out to be. Granted I do hear/feel it hit the bumpstops over railroad tracks or if I'm not paying attention and hit a bad spot in the road, but it's not a constant occurrence like I figured it'd be, and I live in Michigan--we don't exactly have the greatest roads.
If you're wanting the best handling spring/shock combo, they're not for you. They feel more responsive to me than stock, but that's probably in my head for the most part. And if you're wanting a good drag racing combo, don't even bother lowering a car because you'll always hurt your times.
I'm sure all the Strano/Koni fanboys are going to jump down your throat here any minute, so I figured I'd throw my 2 cents in on how they worked for me. I dont doubt for a second that the strano/koni combo is the better choice handling wise...but based solely on price difference and looks, I prefer the sportline/KYB combo.
Lowering a car does not ALWAYS hurt your traction. Lowering the car with springs that have a shitty spring rate will, but a proper spring rate will actually help traction. That being said, Eibachs dont exactly have the best rates. So pick your poison, traction or looks.
Sportlines serve one purpose:To give that slammed look.
Pro-kit, while a better set of springs, is still a tad bit soft. Especially the rears (which will sag). The slightly softer than average fronts, however, gave a nice ride.
My setup on my 2000 Trans Am:
Front Springs: Pro-kit
Rear Springs: Strano
Shocks: Koni 4/3s
Sway Bars: Strano
The car was simply amazing with this setup.
Now Strano needs to start experimenting with G8s
Shocks: Koni 4/3s
Sway Bars: Strano
i put my eibachs (pros) in two years ago shortly after a moser 12 bolt. it handles great but rides so bad (also in MI, GR) that i have driven it maybe 20 times in the last two summers. If you ever plan on putting a larger rear end in, good luck, I guess its an easy way to keep mileage down considering you will end up hating driving it anywhere on these roads. If we had smooth even roads around here, they probably would be fine. rides great on brand new roads but any little valleys i go across over 40 or so, the bumpstops smack nice and hard. also say goodbye to any driveway entrance with any angle to it, i think i got about three inches of clearance at the bend in the middle of my exhaust.
I have the eibach pro kit should I put it in or get rid of it
not hearing good things I have 20s on there would it even be worth it
Furthermore, high tire pressure, and settling for cheap shocks are two things that will both kill your ride quality.
FYI, I've had Kenny Brown Hypercoil springs on my car after having a LT1 pro-kit on it, and it rode a lot better in the rear of the car. Probably because the rear spring rate's a lot higher(168-216) than the LT1 Pro-kit (94-160) and you not hitting the bump stop as hard/often, as the pro-kit
http://img.photobucket.com/albums/v307/black_97mustang/1-2.png[/IMG]
http://img.photobucket.com/albums/v307/black_97mustang/2.png[/IMG]
http://img.photobucket.com/albums/v307/black_97mustang/3.png[/IMG]
http://img.photobucket.com/albums/v307/black_97mustang/4.png[/IMG]
I love the stance that the Sportlines give my car specially with the 18/19 wheel combo that I have. Handling has not been affected and I don't worry about bumps because it's not an offroad vehicle that's why I drive on paved roads! Launch has not been affected either since I have continuously obtained the same 60's as before the Sportlines. If you want the slammed look, Sportlines are what you need. If not, go with Prokit. Overall opinion however points you a different way!
I drove a ls1 camaro w/red eibach springs and stock shocks, it slammed to the ground, but the ride war bad,
I run bilstein shocks, vogtland springs and spohn swaybars, and it feels much better than the eibach's
